tpi computer question
Old Oct 6, 2004 | 08:45 PM
madmax57's Avatar
ok..my tpi car runs great cold..when up to temp it starts to cut out and hesitate when accelarating...only when its up to temp!..if you let it sit for 1/2 hour it will run great until its back to temp again..i have checked grounds and replaced everything except the distr...i think i'm going to swap out the distr. for a reg hei..now is there a way to keep the computer in the cold mode?..sounds dumb but just to see if it will affect my problem...any ideas?.. thanks for the help
max
Old Oct 6, 2004 | 08:48 PM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
cat converter ,if t has 1
Old Oct 6, 2004 | 08:58 PM
madmax57's Avatar
no cats..in a 57 chevy w/painless harness..ran great..returned from the track started all this fun next day..replaced about everything..tired pissed..not having fun!
Old Oct 6, 2004 | 09:23 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Sounds like a glitchy ignition module to me.
...WAG...
Old Oct 6, 2004 | 10:14 PM
madmax57's Avatar
replaced the ignition module...also coil, coil pick up, cap,rotor,esc, chip computer, knock sensor..i about tired of this gonna see about getting a regular hei
m
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
