Vacuum Leak???
Old Oct 7, 2004 | 09:59 PM
92GTA's Avatar
Vacuum Leak???
After installing my new topend (not including heads) I had my head under the hood today adjusting the AFPR and I heard a very distinct hiss like a vacuum leak from the passenger side of the intake plenum towards the rear runners. (nice run on sentence huh )
Anyway, my kpa's are VERY constant according to my data stream and my idle is steady, moving only about 25RPM's at the very most. I've checked for a leak but cannot find one. I thought it maybe a fit problem between the SLP runners and the Accel base on that side.
I don't remember this noise on my old top end. Any ideas???
Old Oct 8, 2004 | 04:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Are you able to monitor IAC counts? If the counts are zero or near it, could be an indication of a vacuum leak...i/e the IAC is extending to close the passage to lower the idle, due to extra incoming air.
Just a thought
Old Oct 8, 2004 | 04:47 PM
92GTA's Avatar
I have my idle screw set to that at idle in gear my IAC steps are 5 and mt TPS is 0.53. I have it set this low on purpose. It was at like 25 counts until I adjusted the idle screw.
So no but good thought though.
See everything seems perfect but I just hear this loud hiss......
Old Oct 8, 2004 | 05:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Time for a little carb cleaner/propane/water test, huh?
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
