Does Cold Start Injector Use O-ring?
Old Oct 11, 2004 | 05:32 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Does the cold start injector use an O-ring? The car is an 87 305 tpi. I did not see one on there when I took it off and I am wondering if there should be one.
Old Oct 11, 2004 | 06:32 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Yes, it's supposed to have an o-ring.
Another thing, when you put the injector in make sure it seats flat. The metal the bolt goes through is very soft, the injector will **** to one side and it will bend very easy causing the o-ring to not seat in the hole.
I've had to straighten out that mounting hole a couple of times because the bolt was tightened down without the injector seated properly.
Old Oct 13, 2004 | 05:05 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Yes, it should have one. Oil the o ring first so it does not tear when installing the injector. When I reinstalled mine, it snapped into place when I slowly applied more and more pressure.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
