a/c delete pulley
Old Oct 12, 2004 | 11:39 AM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
a/c delete pulley
1.who make an a/c delete pulley for a 1988 gta(5.7)
2.what engine came in the 1989 Corvette ZR-1, 1990 Corvette, 1990 Corvette ZR-1 and the 1990 Pontiac Formula Firehawk
3. will a high stall converter like a 4K still be streetable?
Old Oct 12, 2004 | 02:13 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
1.) https://www.thirdgen.org/techbb2/sho...hreadid=251855
3.) You normally want to match up the converter with the camshaft used, gears, transmission, induction, etc... That's why when you order expensive converters (like ACT or PI) they ask for all that stuff. I have a 2400 ACT stall and it's very streetable... few guys I've read about in posts say 3200+ isn't bad either.
Also depends if you get the lockup or nonlockup kind I'm guessing too... either way you'll lose a little MPG from the extra slip, nothing to worry about though.
Old Oct 13, 2004 | 07:41 PM
Calico's Avatar
1989 Corvette ZR-1
2.what engines came in the 1989 Corvette ZR-1, 1990 Corvette, 1990 Corvette ZR-1 and the 1990 Pontiac Formula Firehawk.
I'm gonna be looking for a new engine in the near future so I'm looking for a good platform. Also I check the stock 1/4 mile times in these car and saw they were pretty fast...mid 13s. Anyone have any idea what engines these cars have also what trannys....I noticed that even the late 80's corvette has a 6sp manual
oh yeah I've got a race with my friend against his turbo supra it runs low 15s all stock what times can I expect my stock car to run?
Old Oct 14, 2004 | 02:29 PM
Camaro Project's Avatar
Car: Chevy
Engine: Largest Factory V6 on Earth
Transmission: 700R4 w/ Trans Cooler
Try these links. Some times seem to be very off though:
http://www.angelfire.com/pa3/ford/performance1.htm
http://www.car-stats.com/stats/search/choosemake.aspx
They've got you at 15.9, which I don't think is accurate. I think you should be in the low 15s-high 14s or better---if your ride is running right.
Old Oct 14, 2004 | 06:37 PM
Calico's Avatar
what is it that causes the ls1 to do so much better on gas than my 350tpi? what can I do to improve my gas milage?
Old Nov 4, 2004 | 12:35 PM
Calico's Avatar
gm parts direct shipping is ridiculously high! does any one know where I can get these pulleys for cheaper? smog/ac delete?
Old Nov 4, 2004 | 04:41 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
if you dont wanna pay for the shipping that part can be gotten at any gm dealer but there gonna ream you just drop for the shipping and if your worried about gas mileage get a toyota
Old Nov 5, 2004 | 08:49 AM
Calico's Avatar
naw i don't want a toyota just better milage....the ls1 gets 26mpg on the highway...wtf I thought parts were cheap for these cars?! $100 for 2 oem pulleys....
Old Nov 5, 2004 | 02:33 PM
Engine: 383 SBC
Yeah, GMpartsdirect.com jacks up the shipping but in most cases I can still get the parts I need through them cheaper than the going to the Dealership. Only downsight to GMpartsdirect is they do have a wide shipping range. At times a part may take 4 days to get to your door other times it can take 2 weeks depending on which place has the part.
You could always try on ebay... course I see the pulleys selling on there 45 to 65 bucks + shipping for the ac delete (for some reason people are still buying them).
Old Nov 5, 2004 | 03:59 PM
brutalform's Avatar
correct me if im wrong, but, didnt the firehawk debut in 1992?
Old Nov 5, 2004 | 04:58 PM
Abubaca's Avatar
First firehawk was in 91. I think there was 6. They used a traditional Chevy small block/350. It was modified a bit, and had the T-Ram TPI manifold. They used a ZF6 speed tranny, same as the ZR1.
They are, as long as you don't buy from GM. Those pullies only come from GM.
Old Nov 7, 2004 | 11:02 AM
Calico's Avatar
Is there anyway you can send me any info on the fire hawk...what body it did it have what colors were they? T-Ram TPI manifold and how can its presense benifit me? Is there anywhere I can see some pics of a 3rd gen firehawk?
Old Nov 7, 2004 | 12:40 PM
Abubaca's Avatar
Do a search for "FIRHAWK"
Old Nov 7, 2004 | 11:24 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
That search might not net any results except for this thread. You may want to search for "FIREHAWK"
Old Nov 8, 2004 | 11:20 AM
Abubaca's Avatar
hehe....LOL
Old Nov 8, 2004 | 12:57 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: a/c delete pulley
'89 ZR-1.....Was not sold to the public. Gm made a number of '89 ZR-1's but they where meant as press fleet evaluation cars.
'90 ZR-1.....Had a 5.7L 32 valve, 16 injector, variable intake runner length V8. It shared the same bore spacing as the standard SBC but that was it. It was engineered by Lotus/GM and was built by Mercury Marine. They sound like the devil's sewing machine when wound out. My favorite car of all time. Long live the king:hail:
'90 Formula Firehawk....I'm pretty sure that the Firehawk didn't recieve an RPO until the '92 model year. I know SLP built a pilot car in '90 or '91. I catually have an old Hot Rod article about it.
Old Nov 12, 2004 | 11:40 AM
Calico's Avatar
I try but all I come up with is the 93-2000 firehawks
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
