Which brand of engine oil and filter do I choose for a 305 TPI?! Help!
Old Oct 13, 2004 | 05:21 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello everybody!
This site is so full of people that know their stuff, I wanted to ask some things.
I have a 1988 Pontiac Trans Am GTA, 305 TPI, automatic transmission, T-Top, 9 bolt 3.27 rear and pretty much every options except leather. The car has about 115 000 miles all original and NOT one single modifications.
The problem is, when I go to buy some oil for the engine, I never know what to choose... Their's so many brands, type, etc...
So, I wan't the expert advices.
I wan't regular oil, NO semi or full synthetic.
So what's the best in regular? By the way, my car doesn't burn any oil if that can help... Should I use 5W30 like it was recommended back in 88? Wich brand is the best?
What is the best brand of oil filters too?
Hope to get an anwser fast, buying the stuff in 1 day max.
Thanks a lot!
Old Oct 13, 2004 | 05:25 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I usually use royal purple synthtic but when my money isn't right I use mobile 1 don't know why just do
Old Oct 13, 2004 | 05:35 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I wish I had enough money to buy full synthetic every time I change oil but I don't... That's why I wan't to know what is the best in regular oil and filter...
Thanks!
Old Oct 13, 2004 | 05:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Most dino-oil these days are pretty comparable, so mostly comes down to your own taste.
As long as you stick to a reputable brand, yuo shouldn't have any worries...Valvoline, Mobil, Shell, etc...
5w30 is probably too light, mostly used to squeeze that last .005 MPG out of the car. A 10w30 would be a better choice IMO, also best to check versus the climate you're in.
But I'd have to ask you this, you have a 115K on the clock and you don't use any oil...why not continue with what you've been using?
Seems to work pretty well
Old Oct 13, 2004 | 06:15 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I was gonna buy 4.73liter of Penzoil 5W30. How much oil is needed in a 305 TPI? Do I have enough with a 4.73liter? Or maybe too much?
I was also gonna buy an AC-Delco filter at the GM dealer.
I was doing the oil/filter change at a shop... That's why I didn't know what to use...
I live in Canada. So the snow is coming soon already... The car is going to be in a garage (non-heated) until april. We don't have extremely hot temperature when the car is out from april to the end of october. Maybe a month or two.
Old Oct 13, 2004 | 06:23 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Here's a pic of my 115 500 miles beauty
Attached Thumbnails Which brand of engine oil and filter do I choose for a 305 TPI?! Help!-mini-photo-081.jpg
Old Oct 13, 2004 | 06:27 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You've kept her in pretty good shape!!
I'm sorry, but I'm metrically-challenged...with a oil and filter drain, you'll need 5 quarts.
Old Oct 13, 2004 | 06:30 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
So that means 5 liter... I won't have enough then. You are sure? With 5 quarts do you have a little more than full on the dipstick?
Old Oct 13, 2004 | 06:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't think 5 quarts is 5 liters...otherwise there wouldn't be a metric system
Shouldn't register too high, if any, to worry about. If 4.73 liters is 5 quarts, then dump it in, you'll be fine.
Old Oct 13, 2004 | 07:54 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Thanks a lot!
Old Oct 13, 2004 | 08:26 PM
92GTA's Avatar
I have 124K and I run Royal Purple 15W40 with a GM PF1218 filter. Used to use the PF25 and PF35.
If you can't afford a real synthetic like RP then just use Mobil 1 or Quaker State...
Old Oct 13, 2004 | 10:27 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I use 10w30 Castrol GTX in summer and when park it for winter i use 5w30. Just had a brand new engine put in and i am going to be using Castrol GTX.
The key is the regualr oil change and the engine should live long and happy.
Old Oct 14, 2004 | 10:56 AM
Camaro Project's Avatar
Car: Chevy
Engine: Largest Factory V6 on Earth
Transmission: 700R4 w/ Trans Cooler
My 4.3 V6 takes about 4.5 quarts. I'd get 5 to be sure. Each quart= .946 liters, so the total should be 4.73 liters. You'll probably be okay with 4.5 though.
Old Oct 14, 2004 | 11:40 AM
Parrydise7's Avatar
You might want to do a search. This topic comes up all the time. Another place you can go for info is bobistheoilguy.com.
Old Oct 14, 2004 | 06:10 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
5 qts mobil1 5-30 and a PF1218 ac delco filter, she has 130k miles from the rocker arms to the oil pan and still runs like new
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
