TB vaccum fitting - ported or not?
Car: 89 Formula
Engine: 355
Was thinking of using the small fitting under the tb for the adj f/p reg on my stealth ram but wanted to know if it ported (no vac when tb closed) or unported (sees vac all the time). If I can find a fitting to fit the back smaller holes I use it but if not I want another option.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
It does not see a full vacuum signal all the time, only under open throttle conditions (since it is originally for EGR)
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
