vortec heads stock lift
Old Oct 18, 2004 | 03:36 AM
billyhoss's Avatar
can someone tell me what the stock lift on a vortec head is, casting 906? also will my stock center bolt valve covers off a 91 z fit on these heads and can i use 1.6 rockers with them at say 490(if they can take that lift stock or not i will get them milled to work) max lift with the stock covers, i have searched but could not find my answers, thanx if u can help
Old Oct 18, 2004 | 03:47 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Factory lift is ~.450"-.480" as cast. 1.6 rockers depends on if it will take the valve lift that far. I would have them milled for anything .470" or more.
VC's should fit.
Old Oct 19, 2004 | 07:50 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
bone stock vortec truck with zz4 cam 474/510 no problems at all!
Old Oct 21, 2004 | 05:58 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Ive read that if your going to have a valve lift over .450 you should have the valve guides machined for guide to seal clearance, and also have the pushrod holes elongated on vortec heads.
Old Oct 21, 2004 | 08:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You mill the guide bosses for more room between the guide boss and the bottom of the retainer.
Only elongate the pushrod slots if you plan on running 1.6 rockers. You make them larger overall if you run guide plates.
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You mill the guide bosses for more room between the guide and the bottom of the retainer.
Old Oct 22, 2004 | 04:15 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I just barely cleared .454 @ .050 on my Vortecs.
Had to slot the pushrod slots as well. Nothing unusual about my setup except an aftermarket roller cam and matching pushrods.
Even at .454 I was just under the recommended minimum clearance (can't recall, is it the thickness of a penny?) but since this is not a high RPM motor, I decided to run it. No problems so far.
There seems to be a LOT of difference in the Vortec heads for some reason.
Stock lift was something like .420, and the stock springs are very weak as a result.
Old Oct 22, 2004 | 09:09 PM
vortec77's Avatar
Car: 86 T/A
Right, He asked if he could use 1.6 rockers with vortec heads.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
