What valve springs???
Old Oct 20, 2004 | 12:17 AM
92GTA's Avatar
AFR 195's
509"/530" lift camshaft
Crower Stud Mt 1.5 Roller Rockers
What valve springs should I buy? Looking through Crowers catalog at their springs I'm just lost The AFR heads use a 1.450 O.D. spring and looking at Crowers catalog I would then use P/N 68382-16, but is that right? It lists a spring rate of 463. How do I know what pound springs I should use? I contacted CamMotion but they would not say in their email reply when I asked...
Old Oct 20, 2004 | 12:23 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'm a fan of the Comp 987 series.
Do you know your current installed height? What cam is this?
Old Oct 20, 2004 | 12:38 AM
92GTA's Avatar
I just want to stay Crower so I can order it with all my other Crower parts and have a complete setup from them.
Current installed height, I have no clue AFR does not list installed height for thier springs on their site. Crower shows an installed height of 1.900 for thier springs though.
It's a custom grind cam from CamMotion...
Old Oct 20, 2004 | 02:24 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I wouldn't attempt to get particular over who makes the valve spring, just so you can stay all one company. I would much rather get the valve spring best suited for a particular application.
But, your call. Find one with similar specs to the 987.
Old Oct 20, 2004 | 09:33 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Personally for cams in the .5-.600" lift range I prefer COMP 987s. Great spring w/ great quality and durability. For higher lift a company like ISKY or Manly w/ their duals are better, but for you application I say the 987s.
Crane makes a similar springs, but I can't remember the PN...
Old Oct 20, 2004 | 01:29 PM
92GTA's Avatar
Thanks!
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
