anyone bought this? will it work?
Old Oct 20, 2004 | 05:29 PM
mcwille's Avatar
Car: 1987 Trans am 5.7 TPI
Engine: 5.7 TPI
i have an 87 trans am GTA 5.7 TPI i want to run NOS to keep up with my friends i all ready beat my friend with a 95 mustang GT, but my two closest friends have much tougher car one has a 94 trans am with a LT1 and ever bolt-on/mod you can get plus a nice built trans, stall, and gears. he beats me pretty good but i think i'll be fine with the custom ram air setup i just made and the headers i'm putting on but my other friend there is no way i could catch him with out serious rebuild or NOS he has a 89 RS camaro engine trans rearend gutted out and a supercharged 383 stroker with a 350 turbo-trans and 4.10 gears i think it is 4.10 gears
anyway i want to run NOS but i am not sure about going about it like i said i have a custom ram air setup but space it tight i have a MAF so i made a boot that connect the MAF to the TPI unit and my K&N filter connects to that i had to modify both the filter and the MAF just to make it fit behind the radiator (oh yeah stock TA hood with vents opened up more) so i have LESS than an inch before i an hitting the radiator already so a NOS plate behind the throdle body would cause a clearence problem so i found this in jegs
http://www.jegs.com/cgi-bin/ncommerc...10&prmenbr=361
but it says for LT1 not i know alot of things for the TPI fit the LT1 and vice-versa now will this fit my 87 TPI or is this just a pipe dream? i do not want to have to redo my whole ram air intake just because i want NOS what is the difference in the LT1 and the TPI throdlebodies?
thanks
matt
Old Oct 20, 2004 | 05:45 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: anyone bought this? will it work?
[QUOTE]Originally posted by mcwille
[B]i have an 87 trans am GTA 5.7 TPI i want to run NOS to keep up with my friends i all ready beat my friend with a 95 mustang GT, but my two closest friends have much tougher car one has a 94 trans am with a LT1 and ever bolt-on/mod you can get plus a nice built trans, stall, and gears. he beats me pretty good but i think i'll be fine with the custom ram air setup i just made and the headers i'm putting on but my other friend there is no way i could catch him with out serious rebuild or NOS he has a 89 RS camaro engine trans rearend gutted out and a supercharged 383 stroker with a 350 turbo-trans and 4.10 gears i think it is 4.10 gears
I dont know if this helps at all but ive seen a Nos setup where a jet gets installed in the air duct before the throttle body and after the MAS. Thats a dry system and then theres a wet system where the jets are installed in the runners just before the injectors, ive seen this in a TPI swappers guide. I might be wrong, or off about the Wet system installation, but the dry system looks cheaper and easier to install. Im sure someone will correct me if im wrong.
Old Oct 20, 2004 | 06:13 PM
mcwille's Avatar
Engine: 5.7 TPI
well what would i have to get in the way of jets and things i don't know much about NOS except that above all else i have to have enough fuel so i don't burn up my engine witch is why i also want a safety switch that works off the fuel pressure but what would be the best idea for running NOS in the airduct? and that has to be after the MAFS? like i said i don't know much about NOS it is new to me i have just done work with exaust and intake
thanks
matt
Old Oct 20, 2004 | 08:24 PM
vortec77's Avatar
Car: 86 T/A
thanks
matt
Well, Ive read that you should get a modified ECM chip for calibration so the computer alters the fuel injector pulse width to add more fuel while the Nitrous oxide is activated. NOS should have a set up you can use with TPI. Try contacting them, The last thing you want to do is blow your motor trying to beat or at least keep up with your friends 383. . But then again if that happened then maybe you could build your own 383 or a 406 to spank your friends RS .
Old Oct 20, 2004 | 09:11 PM
mcwille's Avatar
Engine: 5.7 TPI
if i built up a new motor he would too that thats the way we have been since kids that is what i want to keep the NOS on a low profile and i doubt my motor could ever beat his setup i just dont want to get spanked but it would let me beat my other friend's LT1 do you know how i would run the NOS like what parts i would need?
Old Oct 20, 2004 | 09:23 PM
vortec77's Avatar
Car: 86 T/A
Honestly ive never done it before, But i have a TPI swappers guide and it says that NOS has a system for 85-92' TPI models and can be configured to deliver anywhere from 100 to 150 horsepower. To tell you the truth Im surprised im the only one that has been responding to your question so far. Everybody must be watching the baseball playoffs .
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Sep 7, 2015 01:37 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
johanlindgren
Aug 16, 2015 12:16 AM
