2 maf's on a tpi car? can it be done?
Old Oct 21, 2004 | 10:40 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
since there isnt ANY room from the tb to the radiator i was wondering if anyone has split the intake pipe and ran 2 maf sensors? just something i thought of the other day.... if u moved the battery to the back took out all the junk on the other side split 2 pipes and have them tuck into the spots in which u removed stuff? didnt knwo if it could be done just askin
Old Oct 22, 2004 | 01:07 AM
Morley's Avatar
To do that you'd need a "translator" of sorts, to average the readings from the 2 MAF's to a single signal that the ECM can use.
Old Oct 22, 2004 | 10:26 AM
QuickGlass's Avatar
Why can't you use just one maf. You would then measure half the air going into the engine. Then burn a chip to calibrate it.
You will be able to read double the air flow with half the resoulution. 255 gm/sec would now equal 510gm/sec.
Wouldn't that work?
Old Oct 24, 2004 | 06:23 AM
Verviticas's Avatar
Engine: L98 5.7
Personally, i think the maf would be slightly off (leanwards), Because the maf side would be slightly more resistive then the free flowing side. I know the maf doesnt resist much air at all but when air had the option of another path entirely its much more profound.
me thinks. 2cents
Old Oct 24, 2004 | 11:06 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Been discussed before. The MAF issues have been hashed to bits a few years back. Some work is still being done, but not much good progress.
ALSO - If anyone has a good contact at GM corporate, please PM me.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
