Do I need the brake light switch wired to ecm for custom TPI conversion?
Old Oct 24, 2004 | 07:55 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hey guys, I'm out in the garage finishing wiring my Painless MAF TPI conversion on my fuelie headed 327. The Painless harness has a wire that connects to the brake light switch with an SPDT relay. Basically, when the brakes are not on, this wire to the ECM receives 12V, and when the brakes are depressed the relay removes the voltage. Painless says this signal is for the lockup converter, so it knows when to unlock. I have a 4 speed manual. If I just leave this wire not connected to the brake switch, will the ecm still be happy?
Old Oct 24, 2004 | 08:57 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
It should work fine without that connected.
Old Oct 24, 2004 | 09:31 PM
Car: 2000 BMW M5
Thank you much!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Bull86
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
