TPI in tank specifications.
Old Oct 27, 2004 | 12:14 AM
PerthZ28's Avatar
TPI in tank fuel pump specifications.
Does anyone have the rated fuel flow [gallons or litres per hour] and pressure on the stock TPI in-tank pump?
Old Oct 27, 2004 | 01:07 PM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
According to http://www.fuelinjection.com/portinj.html The pum p is rated at 24 GPH at 50 PSI. My dandy little measurement converted translates that to about 109 LPH. I don't know how much HP it can support, I know I fall out of regulation with my 406 SBC under heavy load. I probably make 425 HP at the Flywheel. A Walbro 255 should be showing up at my door sometime soon.
Hope that helps!
Old Oct 27, 2004 | 06:21 PM
Guest
Guest
Posts: n/a
From AC Delco spec book
https://www.thirdgen.org/techbb2/sho...hreadid=204683
Old Oct 28, 2004 | 06:41 AM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
Wow!
There is a lot of difference between what the Delco book says, and FIS says the rating is.
It is just too easy to give false information around here!
Orr89RocZ
Apr 25, 2016 08:28 AM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
