tpi distributor
Old Oct 27, 2004 | 11:45 PM
lonkishna's Avatar
tpi distributor
This is probably a question that has been answered a million times, but I want to know if you can put a msd pro billet distributor in a tpi car? Does the computer need to be hooked up to the distributor for the advance or can the pro billet and a msd box take care of it. Let me know thanks.
Old Oct 29, 2004 | 02:14 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I just has a MSD pro billet distributor installed in my 1989 GTA 5.0 litre TPI engine with a blaster coil. They make a replacement which is worth the investment.
Old Oct 29, 2004 | 11:49 PM
lonkishna's Avatar
What is the product number of the msd distributor for the tpi?
Old Oct 30, 2004 | 01:17 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
The distributor is a Pro-Billet Late Model GM V8 PN 8366. You will need a blaster coil with this distributor. It hooks right up to all the existing wiring. I have not installed a multi spark ignition box; however, it can be incorporated into this inginition set up. These can be viewed on the MSD web site and you could discuss it with their technical staff.
Old Nov 1, 2004 | 08:02 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i bought a direct replacement for my 89 iroc 350, with the seperate coil, it was $400 but have you checked pricing on a brand new replacement??, about the same, and this msd is much nicer,
Old Nov 4, 2004 | 09:24 PM
lonkishna's Avatar
the real question is does anyone know if the car can run if the distributor is not hooked to the computer? Can you run a standard msd distributor in a tpi car?
Old Nov 4, 2004 | 09:40 PM
brutalform's Avatar
MSD #8366 retails for $289.00, in the mailorder catalogs...
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
86IROC112
Aug 17, 2015 02:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
