MAF screens turning red?
Old Oct 28, 2004 | 12:14 PM
just2quickz28's Avatar
Car: 86 IROC
I had a painless wiring kit installed into my car it, when i have car running and i shut it off to check things out i notice that the inside of my MAF sensor is turning red, my car is running terrible is there a short in the wiring (crossed wire or something) or is the MAF sensor just trashed?
Matt
Old Oct 28, 2004 | 02:15 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The MAF cars have a burn-off mode. When the engine is shut off, the ECM sends something like several hundred to 1000 volts thru the MAF senseing wire to burn off residue picked up while driving around. It only lasts a few seconds I believe.
Can someone else give the correct voltage for burnoff and the time increment.
But the sensing wire should glow red for a few seconds, that is normal and should not be connected to any drivibility problem.
Old Oct 29, 2004 | 08:39 AM
Car: 86 IROC
can someone post the voltage for each wire at the MAF sensor because it is turning red even with the car running
thanks
Old Oct 30, 2004 | 04:56 PM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
Well, I did not have that kind of problem, but check this out:
MAF sensor CODE 34
Old Oct 30, 2004 | 05:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If the wires are glowing while running, then I'd guess the burn-off relay is stuck, or always energized.
Wiring diagram would be beneficial for you at this point.
Old Nov 2, 2004 | 09:40 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
as far as volts that shouldn't cause the red doc. amperage generates quite a bit of heat though so what you are prolly seeing is a few amps going through that small wire
Old Nov 4, 2004 | 03:50 PM
Steve89GTA's Avatar
If the burnoff were to fail, is it safe to say the MAF will degrade and eventually kick the bucket? Does the computer set a code if the burnoff fails to kick in? I'm guessing not...wondering cause mine is original (relay) ...and if I should change it just to be safe.
specialized
Jun 18, 2022 09:26 AM
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ZsTransAm
Aug 11, 2015 07:30 PM
