BBK TPI intake setup ($399.00)
Old Aug 24, 2007 | 10:27 AM
  #401
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: BBK TPI intake setup ($399.00)
I'm ready for the surprise.
Bill
Old Aug 24, 2007 | 10:37 AM
  #402
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Let's not forget that BBK makes throttle bodies for our cars including a 58mm version. So you can bet it will be made to use one.
Old Aug 25, 2007 | 02:09 PM
  #403
Drac0nic's Avatar
From a design stand point I like the Ford intake better, way easier to mod and with a truck lower the intake can be taken a lot further. From a looks standpoint the TPI is hard to compete with. There's a reason why they're so popular with the street rodders. Hope to see this intake soon, curious as to what it looks like. Since they say a "stock" motor the power levels they are getting may be great or not as much so. Afterall, don't forget that from best to worse the cams have 20-25 degrees different intake duration, the ECU systems are very different in regards to adaptability. Without the AFRs being logged it could be extremely lean and leaving tons of top end power on the table, and we wouldn't be the wiser esp on a SD setup.
Old Aug 27, 2007 | 04:47 PM
  #404
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
so if im following this right... and i would like to think that i am....
this intake made 211rwhp ... right? ok
the Z28 was rated at 245hp(at the crank) from the factory... take the drive train loss of the 700R4 of 20%..at you're at 196rwhp in stock form
so you guys got 211rwhp.. a gain of 15rwhp..
sooo...... you get 15rwhp or 265hp at the crank???
guess i'll just have to wait and see the results of a modified motor, but even then it will be subjective.. they need to take a car that has a cam,headers, cat back.. with a stock TPI system.. dyno it.. then pull off the stock intake and put theirs on.. leaving the fuel trims the same.. then dyno it... they redo the fuel trims (tune it) then report the #'s...
Old Aug 27, 2007 | 07:58 PM
  #405
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you can't just go by peak numbers, take a look at the graphs in post 314. there isn't a big gain in peak power, & the peak torque is actually about 16 pounds lower with the BBK than it is with the stock intake.
its that with the BBK intake, horse power is still on the rise when the stock intake peaks at around 3900 RPM & the BBK peaks around 4400 & doesn't drop to the same peak power of the stock intake till around 4800 RPM. the BBK adds 50 horse power around 5100 RPM, 138 for the stock, 188 for the BBK.
the torque shows about the same increase at 5100, 143 for the stock, 194 for the BBK.
what this intake is doing is what the TPI needs, extending the useable RPM range
i do hope they make a vortec base for it.
Old Aug 28, 2007 | 09:13 AM
  #406
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Indeed, the reason the HSR and SuperRam do so well is that they extend the engines powerband a great deal, with only a minor loss at the very bottom end, which once you hit 2nd gear, you never see again.
Most TPI 350 cars have transmissions calibrated to upshift at about 4500rpm. My stock 700r4 upshifted at 4500 on the tach, and then dropped to about 3500, and repeated. When I put the trans go shift kit in it, with the other stuff it started shifting at 5000rpm, and recovering at about 4000. So TPI's grunt is really only apparent at launch, and when cruising.
Old Aug 29, 2007 | 12:14 AM
  #407
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Does anybody else here know that since this thread started Professional Products came out with a new sbc efi intake and the tpi throttle bodies? The intake is basically a single plane they plumbed for efi, and sell a fuel rail kit for it. You could get the kit, intake and TB with less money than you will probably pay for this "new" intake. You will make more power with the professional products and have it in however long it takes to ship it too. My two cents I think you all have been crazy to give this intake the time and attention.
As for the R and D thing, then why were there new intakes/superchargers availible for the new mustangs 6 mo after they came out? Why could you buy new cams for any LS engine almost the same time they came out?
Old Aug 29, 2007 | 12:40 AM
  #408
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, but those intakes you mentioned do not have provisions for EGR, which some of us have to have. We're hoping this BBK intake has EGR and will be made 50-state legal.
Ford released the specs and provided several new Mustangs to the aftermarket for them to create new products for, so they would be available at the same time the Mustangs launched.
The first new cams for LS1 engines were reground big block chevy cams. It wasnt until sometime in 1998, after the LS1 engine had been out for over a year, that specific LS1 camshaft were made.
Old Aug 29, 2007 | 12:57 AM
  #409
Guest
Guest
Posts: n/a
Dont know about GM, but Ford sent out cars (Mustangs, new F150's) way before the actual release date. They had plenty of time for R+D before the cars arrived, not to mention none of it was back burner.
Old Aug 29, 2007 | 08:09 AM
  #410
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
We should just quit posting about this until BBK does something. It's obvious that this project maybe important to us but it does not seem like a priority on their part.
Just an observation....
Old Aug 29, 2007 | 11:46 AM
  #411
F-Body Demon's Avatar
I think we need a BBK contact e-mail address. Something direct if possible, maybe to the director of the R&D dept. Hint Hint.
Dont forget this guy said NO ONE at BBK knew about this thread until he STUMBLED on it. These are mostly Mustang guys were talking about. Most of them could give a hoot about the 3rd Gen F-Body. We just have to appeal to the shared love we all have....money.
Old Aug 30, 2007 | 10:50 AM
  #412
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
Transmission: 700-R4
...i dont see this new efi manifold from professional products. anyone have a link?
Old Oct 9, 2007 | 08:55 PM
  #413
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
So uhhh, any news on this intake?
Old Oct 9, 2007 | 09:25 PM
  #414
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
http://performanceparts.com/part.php?partID=373764
It's not a simple bolt on and go. You'd need a TB, and a way to connect the two.
Old Oct 9, 2007 | 10:21 PM
  #415
Bryan Rogers's Avatar
I just sent the proto intake out to get photo'd for the new catalog.
We still need to test it on a built motor and of course there are lots of little details to work out before it hits the streets.
We are still working on it.
Old Oct 9, 2007 | 10:42 PM
  #416
Car: 1989 GTA
Engine: 369 TPI
Thats good news. I know quite a few people waiting for it hoping it will be superior to what is on the market. Most of us are not impressed with the Edelbrock TPI intake. It leaves a lot to be desired. If yours is designed correctly you will take over the market overnight. With the internet word will spread quickly.
PS: The Accel Superam uses the Edelbrock intake and that is the weak spot in that system. I understand from your prior post that your intake system somewhat resembles it. You have a golden opportunity please don't waste it.
Old Oct 10, 2007 | 08:56 AM
  #417
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Is the Superam system even available anymore, aside from a complete injection system?
Old Oct 10, 2007 | 09:33 AM
  #418
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have a super ram. When I get another project car in about a year, I may have to get this Intake setup.
Old Oct 10, 2007 | 05:33 PM
  #419
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Awaiting with baited breath!
Old Oct 13, 2007 | 09:01 PM
  #420
davel98's Avatar
Car: 1990 vette
Transmission: ZF6
Figured I'd bump it up, and see if any word has come out about it.
Any time frame Bryan? I know its hard to say, but I'm sure there are a lot of guys looking for a winter project like myself. I don't know too many people that would want to install one in the middle of the summer.
Old Oct 13, 2007 | 09:53 PM
  #421
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
what new stuff how much flow?
Old Oct 16, 2007 | 07:31 PM
  #422
JohnC's Avatar
Car: 1988 IROC-Z
Any updates? I want one of these
Old Oct 17, 2007 | 10:36 PM
  #423
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
this is like a long movie.... just get to the ending
im not in the market currently, but i AM excited to see the intake!
Im assuming this intake would work on a non TPI 350 as long as the traditional conversion steps are takin?
Old Oct 18, 2007 | 02:44 PM
  #424
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
NICE sig pic man!
Old Oct 20, 2007 | 11:49 AM
  #425
gflo383's Avatar
Car: IROC Z
just saw BBK on horsepowerTV, they showed the new intake base in the begining stages....
anyone else see that?
My sig rockit? thanks
Old Oct 20, 2007 | 12:55 PM
  #426
robert1's Avatar
Yep, I did, and that's how I got to find this thread. The runners look bigger, and they got rid of that hump in there too. I can't wait to get one!
Old Oct 20, 2007 | 01:54 PM
  #427
JohnC's Avatar
Car: 1988 IROC-Z
+1!
Old Oct 20, 2007 | 03:27 PM
  #428
Car: 1989 GTA
Engine: 369 TPI
OK Bryan now that your intake manifold has been on TV lets post a picture of that at least.
Old Oct 20, 2007 | 04:10 PM
  #429
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Goto http://www.horsepowertv.com/
You could at least see the manifold. It looks like the FIRST manifold. It also has an EGR setup in the same location.
Let the main video play then you will see the manifold.
Old Oct 20, 2007 | 05:30 PM
  #430
Car: 1989 GTA
Engine: 369 TPI
You right Vincent. It does remind one of the First Intake Manifold. This BBK setup could be a real winner. I was able to stop the presentation and look it over pretty good. Now if one could see the runner entrance and the head entrance.
Looks like all the work I did to modify the First Intake manifold they had already incorporated it on the BBK intake manifold. I will be interested in the runners and plenum. This could be the death of the Edelbrock TPI setup and the rest of them for that matter.
Now Vincent all you have to do is to convince them to use your car for testing. They might be able to get 500hp at the motor out of it with the proper porting.
Old Oct 20, 2007 | 07:28 PM
  #431
Abubaca's Avatar
Well, it looks pretty good, but there's only so much to see of course from a screen shot.
I'm not sure if I've already said this, since this thread is forever old, but for me it needs to perform at least "pretty good", be cost effective, and look good. To date, IMO, there's not an intake that does all three.
Old Oct 20, 2007 | 08:58 PM
  #432
VincentZ28's Avatar
I don't give a damn about how it looks. As long as it works. It's all good with me. Just hope it's an easy install.
Old Oct 20, 2007 | 09:29 PM
  #433
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Id like to see the rest of the intake setup. All they showed was the base.
Old Oct 20, 2007 | 11:17 PM
  #434
Kevin91Z's Avatar
I like how the narrator said they were working on an LS1 intake, and then the worker said it was a tuned port intake.
Old Oct 20, 2007 | 11:35 PM
  #435
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Looks like a purty big ****.
I wont complain if its affordable, course LS series looks better and better lol
Old Oct 20, 2007 | 11:57 PM
  #436
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I did make one observation. Sure it is in unfinished form, but the straight intake lines on each side indicate a possible L31/Vortec fitment option...
Old Oct 21, 2007 | 04:32 AM
  #437
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Here are screen shots form the show.
Old Oct 21, 2007 | 03:15 PM
  #438
Car: 1989 GTA
Engine: 369 TPI
I wonder how they are going to bolt the runners on. Maybe one top middle and two outside bottom. If that is the case the top middle would have to come in from the backside.
Hard to say without having one in hand but maybe the runners could use some more metal around them. Not sure how far you can open them up from the picture. Maybe they are big enough already.
Thanks Axoid for posting the pictures.
Old Oct 21, 2007 | 03:23 PM
  #439
jbpnumber03's Avatar
I saw this also. When I saw this I thought they were in the first shop, and then they said it was BBK. The intake is HUGE. I guess that HUGE equals more air.
Old Oct 21, 2007 | 03:37 PM
  #440
JohnC's Avatar
Car: 1988 IROC-Z
Now I reaaallly want one
Old Oct 21, 2007 | 04:50 PM
  #441
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Bryan Rogers
My Corvette Photos
The Horsepower TV thing was a tour of the shop with a very general overview packe into a less than 5 minute segment.
The lower intake for the TPI intake was shown as something that was being worked on in our in-house pattern shop.
The idea was to show the viewers that we have an in-house pattern shop, not to focus in on or promote the TPI intake.
As I have stated before, I will post pics here of the set-up as soon as the boss says O.K.
This was posted on the corvette web site
Old Oct 21, 2007 | 05:53 PM
  #442
FerrMaro's Avatar
This is promising. My fingers are crossed hoping this thing isn't as much as the First...$1000 for a TPI intake?
Old Oct 21, 2007 | 08:00 PM
  #443
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
The suspense is killing me !!
I wonder how this is going to compare to the first when it comes to runner to plenum design. It does seem like there is a bit of room on that mani to port out but not too much.
We shall wait and see............
Rabi C.
Old Oct 21, 2007 | 10:32 PM
  #444
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
its better deal than the miniram at 1200. and flows a good deal better than most ported aftermarket TPI stuff....thats food for thought
Old Oct 21, 2007 | 11:00 PM
  #445
Car: 91 maro
ford intakes are gay i love the way the tpi looks my cars tbi but iam ready for the change over to tpi.
is this just the base there building or base runners plenum any one no the rpm range?
Last edited by stevo the torpe; Oct 21, 2007 at 11:02 PM. Reason: Automerged Doublepost
Old Oct 21, 2007 | 11:57 PM
  #446
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I hope they have a L30/L31 Vortec head type fitment option. I could use one on my 396 build rather than a single plane manifold.
Old Oct 22, 2007 | 12:12 AM
  #447
JERRYWHO's Avatar
Originally Posted by jbpnumber03
The intake is HUGE.
Are you looking at the pictures from HP TV or do you have others to make a statment like that.
Old Oct 22, 2007 | 12:31 AM
  #448
JERRYWHO's Avatar
Axoid,
Thanks for the still pics.
The BBK base looks to still have the pinch area from the fuel rail mount to the injector boss, so it will flow about the same as a Edelbrock no more.
And yes I have had Edelbrocks, Extrude honed Edelbrocks and first units on a Flow bench.
Jerry
Old Oct 22, 2007 | 03:20 AM
  #449
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Im asking myself the same question!
..convinced enough otherwise! It looks promising..
Old Oct 22, 2007 | 06:06 AM
  #450
BadSS's Avatar
Based on info cut and pasted from a few of Bryan's posts off the Corvette Forum, the runners are not going to bolt to the base,,, they're push fit with O-rings.
“It assembles as follows
Lower intake to block
Stock fuel rails, EGR, etc.. to lower.
Tubes push fit into lower (seal with O-rings)
Base plate for upper sits on risers that sit on the fuel rail mounting bolts. Longer fuel rail bolts are used. Tubes O-ring push into base plate.
Upper manifold sits on base plate. “
“It'll be steel tubes, a cast aluminum lower, and more than likely a die cast upper/bottom plate.”
“(Runner Length) Right @14" measuring from the mouth where the tubes connect to the upper manifold and down to the cylinder head.”
Previous Post on TGO – “It's a large, open plenum with 1-3/4" tube runners that bend down into an all new lower intake with larger than stock ports.”
I doubt this thing will prove much better if any over the SuperRam as far as out-of-the-box overall performance. Especially with the same ole pinch point as Jerry indicated earlier. The improvement (over the SuperRam) looks to be in the install with the press fit on the runners. However, that means you can’t open up the intake base where the runner slip in. I’d guess the 1.75" runners (outside?) are going to be about the same inside diameter of the ASM LTRs. If that’s the case, it’ll probably make similar and peak power somewhere in between an edelbrock base with semi-siamesed ASM runners and the SuperRam – based on the BBK’s 14” length measurement.
I’m not knocking it,,, sounds like it’ll be a good bolt on intake for moderately modified engines and if the price is any where close to $500, they’ll sell very well. It just doesn’t look like (at this point) any one with welded Edelbrock or FIRST intakes will be trading them in for this one.
