Questions on fuel pump and replacement
Old Oct 30, 2004 | 05:01 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I may be needing to replace my pump soon. I have a bunch of questions.
The system doesnt hold pressure. I think I have been mixing up the fuel return line with the fuel in line. ( I know, )
Anyway, the pressure drop would mean a bad check valve in the pump. Whenver I pinch the hose the pressue will stop falling when the pump is off. But if the pump is on, and i pinch the hose, the pressure goes to zero and the pump stops pumping. When I let go the pump goes back pumping and the pressure goes to normal. Yes, I know, stupid stupid mistake to mix up the lines......
Would a bad check valve cause driving problems like bogging on accel, or hesitation, or anything like that?
The gas tank also gets pressure buildup in the tank sometimes. What causes this and is it normal?
The pump also doesnt turn off after priming. It should turn off after 2 seconds, mine doesnt, it will stay on as long as the key is at run. What causes this?
I have access to a lift. How long would it take to replace the pump? Difficulty? Whats involved?
If I replace the pump, what else should I replace or check while the pump is out and the tank is out?
I read something about a pulstator. Is that part of the pump, or is it separate? Should I replace it? What does it do?
Thanks,
Matt
Old Oct 31, 2004 | 01:06 AM
Morley's Avatar
Re: Questions on fuel pump and replacement
No
Yes it is normal, there is a vent valve that will prevent it from getting too high
Stuck pump relay would be my first guess.
2-3 hours. Make sure the tank is almost empty. Have a pan to catch the gas that will come out when you remove the lines. Have a support stand for the rear axle to hold it after you take the shocks off to lower it a bit more. You'll need to remove the muffler and get the pipe between it and the converter out of the way.
You'll want a new seal for the sending unit/cap. A new strainer filter for the pump and look for any crap floating around in the tank and get it out. Oh yeah! NO SMOKING while working in/around the tank & open fuel lines!
The pulsator was to quiet the pump and keep the fuel flow "smooth". It is above the pump on the sender and should be replaced with either a new one or a suitable size of fuel injection fuel hose.
Old Oct 31, 2004 | 12:59 PM
Matto'85TA's Avatar
Thanks for all the info.
Its good to hear that the check valve wont cause problems like that. Though I think my pump is weak or dieing cause when I am checking fuel pressure and rev it in park or neutral, pressure drops slightly then raises.
Hopefully I am wrong on this and its something else. But at this point I have replaced just about everything and I am still having problems.
Thanks again,
Matt
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
