should i swap back to tpi?
Old Nov 9, 2004 | 06:55 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
this is my situation...
i have an 85 trans am, originally had a 305 w/ tpi, i swapped it out for a '72 350 bored .060 over w/ single plane intake, 850 CARB., ported iron heads, decent cam, etc.... i am interested in doing a mild single turbo set up, because of the simplicity of adding quick power, i have a chance to pick up a TPI 350 (with the rest of a crashed T/A) for $500 or b/o.
would i be better off swapping the TPI 350 in for doing a single turbo set up with like a t03/t04 or t04 with somewheres between 6 and 10 pounds of boost???
or am i better off staying with the carb motor that already has cam, decent heads, and good top end, and just do something like a 100shot of juice? --im eventually looking for mid 12's
(i have a 700R-4 witha holshot 2400 converter, shift kit, and 3.42's for now, if i stay w/ the high revving carb motor im swapping for 4.33's with a 27" tire)
PLEASE HELP!!... ive got three freinds currently running in the 13's with turbo'd mitsubishi's and i NEED to kill their cars in the spring
Old Nov 9, 2004 | 10:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There are an increasing number of people on the boards runing a TPI set-up on a 350 with aftermarket parts that run high 12s low 13s with no power adders. A turbo 350 might be good for 11s. I know Willie's supercharged 5.0 TPI puts out some good times. Search the power adder boards.
For the cost of a turbo rebuild though you could go Mini ram, stealth ram, or super ram (what is with all of the ramming?) and a good set of heads and achieve 12's.
Old Nov 9, 2004 | 11:53 PM
DON 88T/A's Avatar
Yeah I'm with the kid on this one ,A built up 350 should run easy 12's N/A..what you have as it sits could run very well with a good head/cam combination...you mention you have decent head cam,but did not list there specs...swapping your current setup for another/then trying to tune a turbo setup on top of it is a lot for "just"12's..(I would be very happy with "just 12's though!!!!LOL)...If you have no emission worries i would go to town on that 350 you have in your car right now...
Old Nov 10, 2004 | 09:53 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Yeah I should have said that too. A carberator set-up can get you into 12's also. Make sure you get a vacuum advance for cruising though. You could probably save a little money by sticking with a carburator. Then spend the money on more parts and a pity party for your slow friends.
Old Nov 10, 2004 | 10:30 PM
Car: 91 camaro rs
thanks for the advice, i think for now, i will stay with the carb set up (maybe add some juice)
i talked to the guy who i sold my TPI setup and harness to, and he said hes moving out of town and is going to be getting rid of all his car parts so if i wanted it back i can have it for real cheap...
i guess i will pick it up and keep it on the shelf for someother time down the road...
as soon as the snows here and gone i will post times on my current setup (the track is closed here(lebanon valley))
the heads on it currently are 305 heads with a 58cc combustion chamber fully ported/polished, i had the 'camel hump' heads from a 69 chevelle on it but one was cracked. -and the cam i am ashamed to say.. i dont know the specs, all i know is its hydrualic and barely poduced enough vaccuum for my brakes and has a rough idle around 850-900rpm.-the cam was already in the short block setup when i bought it.
the engine has unreal throttle response and extremely fast revving, i swear the response is better than fuel injection and pulls hard from 2500/3000 up to 6500rpms...
Fast355
Dec 2, 2016 06:33 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
