super ram
Old Nov 17, 2004 | 01:21 AM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
super ram
Where is the best place to buy the super ram. How much of a difference will it make , if i have it ported amd matched?
Old Nov 17, 2004 | 10:21 AM
OMINOUS_87's Avatar
Re: super ram
Alot of difference.
If you are putting it on a larger cube motor with heads and cam I wouldnt recomomend installing unless it was ported.
Old Nov 17, 2004 | 10:40 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
On a 350, the SR should be at least port matched, and a little bit of porting would help. Diffinite gains can be made.
As stated above, if the SR is installed on a stroker, the SR should be heavily ported.
Old Nov 22, 2004 | 12:59 PM
Ragtop89's Avatar
Castings in the stock SuperRams suck most of the time.
You'll prolly want to clean that up right off the bat.
Old Nov 22, 2004 | 03:29 PM
purplebird's Avatar
Engine: 5.7 tpi
where is the best place to buy it from?
Old Nov 23, 2004 | 09:30 AM
Ragtop89's Avatar
I got mine used.
I bought the SR plenum and runners port-matched to an Edelbrock big-mouth manifold.
I didn't have to clean anything up - just installed it and ran!
I got eveything for less than $1000.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
