Interesting find K&N Airfilters
Old Nov 17, 2004 | 07:08 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Last winter during the installation of my 406, I replaced the air filter with a large K&N part# RF-104. I liked the filter because it was larger than the cone shaped filter I was previously using and thought that it would flow more air.
For a computer, I use a DFI. In the fuel map, the base map shows engine load and rpm. During the tuning process, the motor would never show 100% load which means that vacuum was still present in the manifold. This generally points toward an intake restriction.
Over the weekend, I changed the filter back to the large cone filter #RE-0870. I immediately felt a sop difference and now the fuel map shows 100% load which means more airflow through the motor.
I can only think that the design of the cone filter is better for airflow even though the surface area of the RF-104 is greater.
www.geocities.com/dzperf
Old Nov 17, 2004 | 08:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Interesting. I'am using the cylindrical RU-1785 on my 350. Was thinking about the cone style. I did a search of the K&N web site but I could not find the RF-104 filter. Also did a search for RF-1040 and got an oval filter. Is that the correct filter number? Allen
Old Nov 18, 2004 | 05:48 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
1989GTATransAm - Yes that is what the RF-104 filter looks like minus the chrome K&N plate. The filter I am now using is a long tapered filter part # RE-0870. The filter length is 9" and has a 4" flange.
Old Nov 18, 2004 | 06:22 PM
Car: 1989 GTA
Engine: 369 TPI
Thanks for the information. K&N makes a filter the same as your RE-0870 but with a 3.5" inlet which will work on my setup. I did not achieve the ET or MPH with my new setup that it should. Granted it still needs tuning but the filter may be part of the problem. Allen
Old Nov 23, 2004 | 04:38 PM
Car: 1989 GTA
Engine: 369 TPI
Update: Received my K&N RE-0920 air filter today. It is of the cone design and I can tell you it is a much better design than the RU-1785 cylindrical that I was previously using. It has a radius on the inlet and a step that matches the tubing I'm using and it is larger. The first two items alone have to help the air flow compared to my previous setup. Allen
InfinityShade
Feb 21, 2016 01:29 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Mickeyruder
Sep 2, 2015 02:45 PM
overdriv
Aug 20, 2015 03:52 PM
