Converting MAF -> MAP
Old Nov 18, 2004 | 01:10 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I've got an 88 TPI motor I want to covert over to MAP. Does anyone know of a good resource/write up on what needs to be done from start to finish?
I know some of the more basic elements, but I am looking for a very detailed piece of literature or even a post here on the board that I missed while searching.
I'd greatly appreciate any assistance. Thanks!
Old Nov 18, 2004 | 02:20 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I'm curious why you're converting to speed density. If you have a heavily modified setup and are burning your own chips, speed density is nice to work with. If you are expecting a power increase from the speed density conversion on a stock or mild engine, you won't see it.
Old Nov 18, 2004 | 02:42 PM
nick418's Avatar
Engine: L98, Hemi 6.2
Leave it MAF, i think MAF is a fine setup!
Old Nov 18, 2004 | 03:27 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Old Nov 18, 2004 | 03:31 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
This is in the DIY PROM Section
https://www.thirdgen.org/techbb2/sho...hreadid=200259
That should explain ALOT of it, also check the diy section for other conversion info.
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
