Ignition module: which coloredwire goes to + and -
Old Nov 20, 2004 | 09:31 AM
dcs89formula's Avatar
Car: 89 Formula 350
I have a green and a yellow wire that hook up to the ignition module on my 89 formula 350. The black plastic connector disintegrated when I disconnected it from the module. It was dark so I'm not sure which one goes where. Help ASAP would be appreciated.
Thanks.
Old Nov 20, 2004 | 01:57 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
On mine the green wire goes on the drivers side terminal, the yellow wire goes to the passenger side.
Insulate the wires so they won't ground out on the dist. base plate.
You may want to think about replacing your pick-up coil
Old Nov 20, 2004 | 04:42 PM
Damon's Avatar
If you're talking about the connector between the magnetic pickup and the module then you might like to know that the blade connectors are different widths for + and - to make the stock factory connection somewhat "idiot proof." The pickup polarity DOES matter, although I'm not sure if it would run if polarity was reversed.
Old Nov 21, 2004 | 01:13 PM
Car: 89 Formula 350
Thanks for the input. I checked the resistance on the pickup and it was okay. Even though the old ignition module checked out OK, I replaced it anyway and haven't had any problems in a day and a half.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
