eliminate cold start injector
Old Nov 21, 2004 | 05:47 PM
GTA Notchback's Avatar
Car: 88 GTA Notchback
I bought a used set of AS&M semi-siamised runners that have the cold started injector hole plugged off.
I know I need a custom chip to eliminate the 9th injector without cold starting issues but what is the best way to block off the end of the fuel rail?
What about the small tube behind the 2nd runner on the driver side, some one told me this was part of the idle circuit and that I would have to block the tube if the 9th injector was eliminated.
Please help.
Robert
Old Nov 21, 2004 | 09:17 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
If the AS&M runners block off the CSI port, then you don't have to worry about the small tube behind the 2nd runner. It will be sealed at the bottom end by the new runner.
What you need is a chip for an '89 car. That was the year they used MAF without the CSI.
You could tap the end of the fuel rail and put in a pipe plug where the CSI tube goes, but be careful about it. Fuel leaks are bad.
Old Nov 22, 2004 | 09:40 AM
aenewman's Avatar
Street and Performance in Mena Ark. have a plug for the fuel rail and it seals with an o-ring. I think when I bought mine it was about $15.
Old Nov 23, 2004 | 07:45 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you want a cheaper solution that works just as well, I've also got caps for $10 shipped. I've had one on my IROC for a couple years now with no o-ring and I've never had a leak, but some people have also used o-rings with them for added peace of mind.
If you're interrested, shoot me an email or a PM.
Old Nov 23, 2004 | 01:59 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
I never got a chip for my 85' when I elimnated my CSI I just hold the gas peddle down slightly when starting the car. It starts with no problem.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
