Fuel rail crossover line question
Old Nov 25, 2004 | 12:29 AM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
On my 89 Iroc where the front crossover fuel line meets the passenger side fuel rail, it is leaking after I changed out injectors. It is making a horrible whistling sound and I was wondering if there is an o-ring in there I could replace and if so would it require I remove the whole fuel rail with injectors again? When I took it out the first time when everything was loose and the fuel rail was kind of pressured up still I was moving it around and fuel was squirting out of that connection.
Old Nov 25, 2004 | 12:33 AM
Guest
Guest
Posts: n/a
There are o-rings everywhere. In order to replace that o-ring, you will have to remove one of the rails though.
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes there are o-rings in there that should have been replaced. You can get a o-ring repair kit from the dealership that will have all the o-rings for the fuel rail.
Old Nov 25, 2004 | 06:24 PM
WaynesIroc's Avatar
Engine: stock 350
Thanks for the replies.
How many o-rings are there to replace on the rail itself and how hard is it to replace them. Do you just pull apart the crossover line from the fuel rail in the same manner that I pulled the injectors out of the rail?
Old Nov 25, 2004 | 06:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
See attached picture for reference.
Old Nov 25, 2004 | 10:10 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
man I have to get a hold of those GM exploded view diagrams, where did you get it?
Old Nov 25, 2004 | 10:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
GM service manual:lala:
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
