MAF burnoff relay code 36
Old Nov 27, 2004 | 05:43 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
On my 89 IROC-350/700R4-TPI--getting a code 36. Done a couple searches and found out it is located on drivers side firewall by the brake booster. I have 3 relays there, and the 2 closest to the fender are the same, I know (I think) from reading one is for MAF power and other is for burnoff.
Any way to tell which one is actually the burnoff relay?
Any way to trouble shoot and find out if this is actually the problem?
Maf itself seems to be working fine--car is running good like always.
Thanks,
Craig
Old Nov 28, 2004 | 12:59 AM
Morley's Avatar
You can take the inlet duct off the MAF and start the car and then shut down after a minute while looking in the MAF ( dark or dim lighting preferred), if the wire in it glows burn off is working...if it doesn't....relay time
Old Nov 28, 2004 | 10:39 AM
rsn932's Avatar
on mine, the one closest to the fender is the burnoff relay, the second one from the fender says "maf power" in little letters on it. not sure what the third one is
Old Nov 29, 2004 | 10:00 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Thanks for the info.
Craig
BumpaD82
Feb 26, 2016 02:57 PM
eustodp
Sep 20, 2015 05:09 PM
64goatman
Sep 9, 2015 01:09 PM
Gunsbee
Sep 7, 2015 07:10 PM
