tpi intake gaskets
Old Nov 28, 2004 | 10:42 AM
rsn932's Avatar
tpi intake gaskets
i am going to swap in a 350 and use the TPI from my 305. the 350 is complete except for the intake. my question is what gaskets will i need? is there a kit for all the gaskets i can buy anywhere? i know i need gaskets between the intake and the heads, but what else? arent there gaskets between the runners and the base or the plenum and the base?
Old Nov 28, 2004 | 03:48 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If parts are aftermarket consult the manufacturers.If the parts are gm I would consult the dealer or your favorite parts store. I personally would not take the advise of others for gasket fitment. I would physically match up the gasket with the part. good luck with your project.
Old Nov 28, 2004 | 05:11 PM
rsn932's Avatar
thanks. i found a complete tpi intake gasket set on ebay for only 20 bucks. im considering getting some SLP runners for it, so if these gaskets dont line up, that may be my excuse to buy the runners since they come with gaskets anyway.
Old Nov 28, 2004 | 05:20 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
SLP runners use the stock gaskets. To trouble either way. I normally use the gm(victor) gaskets on stock stuff, The set is very complete including the egr gaskets and all others. Very complete kit for $30 or so. I think it even includes the fuel injector o-rings. A felpro intake gasket is good. Just not as complete as GM.
Old Nov 28, 2004 | 06:25 PM
rsn932's Avatar
ok great thanks for the info
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
