LS1 injectors not a bolt-in for superram
Old Nov 28, 2004 | 03:12 PM
anondude13's Avatar
_
Old Nov 28, 2004 | 03:21 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My LS1 injectors work O-K-DOK-E on my HSR. It is different, I know, but is supposed to be the same heighth. The injectors, when stood up side by side with each other, do show a difference. But anyone who owns the injectors knows that the difference from O-Ring to O-ring is only .08, just under 1/10". Just make sure that they are seated in the rail all of the way and then slowly lower the injector rail assembly onto the plenum. Works fine for me and what I have read from everyone else.
Old Nov 28, 2004 | 03:25 PM
anondude13's Avatar
_
Old Nov 28, 2004 | 03:27 PM
anondude13's Avatar
_
Old Nov 28, 2004 | 05:37 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I am running the accel base and ls1 injectors. yes you need to grind the fuel rail mounts down to get them to seat properly. don't have to take that much off though, and if you decide to go to taller injectors you can just use shims to fit them.
Old Nov 28, 2004 | 05:56 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
arent the ls1 injectors a 5 bar system? if you run them with 42 psi they are equivalent to a 22lb injector. to have them operate at 27-28lb you would have to run 56psi fuel pressure. i am correct right?
Old Nov 28, 2004 | 06:27 PM
anondude13's Avatar
_
Old Nov 28, 2004 | 08:05 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Actually, it depends on what year LS1 injectors you got. '98, '01, and '02s are 28.5#/hr rating at 58 psi. These injectors will flow about 24.5#/hr at 43.5psi which is what our stock fuel pressure is on our 3rd gens.
So there is no confusion. I got a '99 LS1 Camaro SS and an '87 Camaro IROCZ. I have swapped out injectors many times and had to reset the flow constant in the computer.
If you have any questions about fuel flow rates, please ask here.
Old Nov 28, 2004 | 08:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
r3pp3r,
If what I see are the orings on the bottom end of the injectors, then those injectors are NOT deep enough in the intake bosses.
I would expect that you would have a massive fuel leak. Get the fuel rail posts milled/ground down.
I use SVO injectors in my Accel manifold so they must be longer than the LS1 injectors. I have never compared the two.
Old Nov 28, 2004 | 09:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
If you got them from SLP then they are rated at L98 fuel pressure rating for stock injectors.
Old Nov 28, 2004 | 10:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the Superram and Edelbrock base and SLP LS1 Injectors. No problems here. I first placed the injectors in the bores then placed fuel rail on top. Although they are a tad shorter I have no problems. I had to burn a constant of 28# in my chip to get the BLM's where they needed to be. I tried 25 at first and my BLM's were 108 everywhere. Black smoke like no tomorrow
Old Nov 28, 2004 | 10:06 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The LS1 injectors work with the super ram because they work with TPI and they have the same fuel rail and base (even accel base). Based on your picture the injectors are not fully seated. You should not see the o-rings like you do in your picture.
dbrochard
Sep 19, 2015 08:13 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Ranbo108
Sep 9, 2015 12:20 PM
