Retro Fuel Lines w/HSR
Old Dec 1, 2004 | 02:37 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
I have done alot of modification to my car so far, and I plan on doing the HSR swap this winter. I have one major question, My fuel lines come out on the passenger side because the car is an 83. Will I be able to put all of the fittings on that line? and then run braided line to the fuel rail? or under the engine? (how it is now)
Thanks any input always appreciated
Old Dec 8, 2004 | 10:15 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
IIRC, the fitting for the fuel lines on the HSR is on the driver's side. You COULD snake a flexible line over there, but it wouldn't be pretty. I'd recommend snagging some hard lines from a TPI car (ones that come up on the driver side) then work it like a regular TPI to HSR conversion.
Hope this helps!
Old Dec 8, 2004 | 10:46 AM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
Nope, the inlet on a Stealth Ram is on the passenger side -- at the rear. The return line fitting is on the driver's side. I really wish it was the other way around -- it would simplify my plumbing.
-Dave
Old Dec 8, 2004 | 02:45 PM
Car: 83 Trans Am
-Dave
So you did a HSR on an early third gen? or you just have the lines on the passenger side? If anyone has pictures of how they ran line it would be nice to see! Thanks for the info
Old Dec 8, 2004 | 03:11 PM
Engine: 383, 327
Nope, I have a Chevelle, not a third-gen. I hang around here cuz there's decent EFI info.
According to the Holley instructions, the inlet is on the passenger rear, and the return line comes out of the regulator, which is on the driver's side rail. After looking at it for a while, I couldn't come up with a good solution for running the inlet on the driver's side and return on the passenger side.
I have pictures of my HSR (off the car) and could scan the instruction sheet that came with it if you want to check it out. Let me know.
-Dave
Old Dec 8, 2004 | 04:03 PM
Car: 83 Trans Am
-Dave
i would be interested in some under hood shots preferably so i can see where everything is going.
Old Dec 8, 2004 | 10:40 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Run your own new fuel lines from the tank and be done with it. New -6AN hard lines are dirt cheap and easy to flare and work with. It will eliminate you making a creative solution.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
