TBI to TPI....
Old Dec 4, 2004 | 05:58 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
TBI to TPI....
I have an 87 TPI setup i want to put on my 91 camaro... will i have any problems swapping the computers? they look like they hook up the same, and i have the wiring harness for the engine bay.... to TBI engines have most of the same sensors as the TPI engines?
Old Dec 5, 2004 | 12:01 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: TBI to TPI....
Originally posted by flowmasterchevy
I have an 87 TPI setup i want to put on my 91 camaro... will i have any problems swapping the computers?---No.
they look like they hook up the same,---they do not. you have to repin the stock harness or get a new/different one.
and i have the wiring harness for the engine bay.... to TBI engines have most of the same sensors as the TPI engines?---Mostly the same. Knock sensor is different, TPS mainly.
For the love of ***, SEARCH. This topic has been covered a thousand times.
Old Dec 5, 2004 | 03:51 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: TBI to TPI....
If you have to pass emissons, early to late model swaps are not legal at least not in Texas.
Old Dec 5, 2004 | 04:48 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
search for me on the tpi board as I just did this swap on my '92 using a system that just came off an '85 iroc and I used ls1 injectors and an accel base manifold. I ran into every problem in the book.
Old Dec 6, 2004 | 06:42 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: TBI to TPI....
I'd love to see a link to that law.
-- Joe
Old Dec 6, 2004 | 02:01 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
I would check with your states laws regarding engine swaps.
Here is some info for Texas engine swaps.
http://www.txdps.state.tx.us/vi/Misc/faq/engine.html
Old Dec 6, 2004 | 06:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
That law was made so that I could not put a carb on my car (older model) or to perhaps TBI and say "Yeah it is fine and pollutets less. It has been proven that TPI is more efficient, all around than TBI. The emmisions on a TPI car even include two catalytic converters. That is basically the same system that also came in the 90-92s (yes I know what the differences are). Go to a sniffer and you will pass more easily with the TPI.
Old Dec 6, 2004 | 06:53 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you adapt your TPI setup to a speed density system (repin your existing harness for the 730 ecm), then you can just say that you have a TPI out of a 91 Z28... I'm going to be doing just that (repin TBI to SD TPI) on my brothers '91 Bird this winter (although I don't have any emissions requirements)...
Old Dec 6, 2004 | 07:40 PM
Car: '91 RS, F41
Transmission: WC T5
my main concern was using a non vats computer in a vats car... i can find alot of info about vats, but it never discusses that... anyone have any info on this?
Old Dec 6, 2004 | 07:54 PM
thirdgen88's Avatar
Car: 1995 Corvette
yet another reason to use a SD setup..
Search around a bit, there are many great posts about TBI to TPI conversions (including ones that detail repinning your existing wiring harness to a SD TPI one)..
Old Dec 6, 2004 | 08:21 PM
Car: '91 RS, F41
Transmission: WC T5
what exactly is repinning? if i have a car with the V.A.T.S system and a computer without V.A.T.S, will it just work like a regular switch or do i need to do the bypassing technique?
Old Dec 7, 2004 | 11:47 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
if you have a 90-92 tbi car(lo3) the 90-92tpi engine harness swaps into place change the fuel pump and go....if you had the 3.1 v6 you would change the dash harness as well as the eng. harness...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
