Gear drive in an 85' TPI car
Old Dec 9, 2004 | 08:26 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
well I did the search thing, and the general consensus is that gear drives made for roller cammed cars dont mess with the knock sensor. I am planning on installing a cam over the winter and need a new timing set and was thinking about a gear drive. I havent seen anything about anyone using a gear drive with a non- roller TPI motor. If there is a good chance of problems I will just get a cloytes timing chain set instead.
Old Dec 9, 2004 | 10:45 AM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
check out jegs they have there own line of gear drives for youre application cheap . i plan on doin the same on my tpi.if all else fails call the tech line
Old Dec 9, 2004 | 11:19 AM
Guest
Guest
Posts: n/a
Doesnt matter if its flat or roller, just stay away from the noisy drives. That seems to be a little more hit+miss than a sure thing.
Old Dec 9, 2004 | 01:07 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, if you get the "quite" gear drive, you should be fine. I know a lot of people running them without problems.
Old Dec 9, 2004 | 01:48 PM
Thanks! Thats what I wanted to hear.
Old Dec 9, 2004 | 01:49 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I would like to hear how the quiet ones work from someones experience along with solid cams.
Even though Iwont be running a gear drive again anytime soon.
They dont work well when you take out the idler gear and forget to put it back in, then turn over the motor to put it in time.......CRUNCH CRUNCH CLANK...lol I bent all kinds of stuff and broke my block
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
