LB9 Question
Old Dec 9, 2004 | 04:39 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
LB9 Question
I am not sure if this is the correct place to post this or not.
BUT
I see lots of things about how well a 350 stock bottom nd is but I am wondering how fast you can spin a stock LB9. OR at least what it can handle as far as HP.
Please dont tell me how I should just get a 350.. I know that but I also know that anything I do to a 305 I can also put on a 350/383/400/454sb and do even better.
If this needs to be moved please email me and tell me where you put it.
Thanks for your help.
Old Dec 9, 2004 | 09:20 PM
Guest
Guest
Posts: n/a
You should just get a 350.
I dont see any reasons you cant push a 305 as far as a 350 on the HP scale. Look up Willie and tell me thats not enough speed for you.
Old Dec 12, 2004 | 09:25 AM
rawley2's Avatar
So you think the stock bottom end of the 305 can handle 6,000 RPM and about 325 HP?
How fast do you think you can safely spin a stock bottom end?
Old Dec 12, 2004 | 10:46 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have goodies on my LB9, and I usually spin it up to 5500.
Now that I have nitrous(75hp shot), I am sure that I am making 325 engine hp.
Gone thru 2 bottles, and no problems yet!
As for the 6000rpm,
1. Why? TPI's don't make power up there anyway.(Unless they are ported and have better heads)
2. I don't know if the factory valve springs would allow it anyway(start to float, and not close)
LB9GTA
Old Dec 12, 2004 | 11:01 AM
rawley2's Avatar
Originally posted by LB9GTA
As for the 6000rpm,
LB9GTA
Well they would if you changed all that. I am thinking about doing a Cheap make over to it until next March when I have time to change over to a 454 SB's..
I am thinking HSR a 230 cam with around .500 lift. As well as porting the heads and adding new springs. Also 1.6 rockers.
Then I can use all the parts on the 454 SB next March and still have fun with the 305. I should also get pretty good at burning PROM's with the 305.
As far as cost it is really not that big a deal. Time is my problem.. Kinda weird,, When I was working for other people I had lots of free time and no money. Now I run my own business and have lots of money but no free time. Funny world we live in..
Old Dec 12, 2004 | 11:12 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Well they would if you changed all that!
If you changed the springs that would be pointless unless you changed the heads and such as well($$).
LB9GTA
Old Dec 12, 2004 | 11:22 AM
rawley2's Avatar
So I cant port the stock heads enough.. That is a horse of a different color. I did not think about that problem. I figured I would just port the **** out of them and be fine. Are they really that bad??
Now I guess it's back to the drawing board..
Old Dec 12, 2004 | 12:05 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
If you are going to go thru the trouble of porting stock heads, go and get a set of Corvette L-98 aluminum heads(off of ebay for about $500-600US)
As for the springs, aren't they about $200(comp cam? brand)
Alot of work for a 305 when you are going to do the 454.(Do you have the block already?)
If not, do a 383. 350 block(everything almost off your 305 will switch over) That is what i plan to do (the cam, headers, afpr, ) will switch over.
I don't know that everything u have will switch to the 454
LB9GTA
Old Dec 12, 2004 | 12:50 PM
rawley2's Avatar
No I have not bought it yet. The one I am looking at is http://www.jegs.com/cgi-bin/ncommerc...96&prmenbr=361 The last one. I will be buying heads for it then also.
I did not think all 350 heads would work on a 305?? If a set of aluminum covet heads will go that route.
I bought this STUPID book called Chevrolet Small Block parts interchange guide but it does not say one thing about what parts will work on what engine??? It has a bunch of generic descriptions of how things work and casting #'s. At least I have a complete list of all the GM SB casting #'s at my finger tips now.
Anyway I thought SOME 350 heads would have problems with the valve hitting the small bore of a 305.
Old Dec 12, 2004 | 01:13 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
The vette heads(aluminum) will work on 350's and 305's.
LB9GTA
Old Dec 12, 2004 | 01:54 PM
rawley2's Avatar
I just have to ask because I dont understand.
Most of the aftermarket heads say they will not work on anything smaller than a 4" bore unless you have less than 450 valve lift. I would think that would hold true with all 350 heads.
What am I missing here. Do the after market guys actually move the valves farther apart?
BTW. Thanks for helping out the new guy.. If you ever need help with a MOPAR product let me know that is where most of my knowledge is. I just have always wanted to build a TPI car.
Old Dec 13, 2004 | 09:36 AM
rawley2's Avatar
Well by reading this info: http://www.flatlanderracing.com/afr180cc.html
The part that reads.
Note: 305 cid requires 1.940/1.550 valves for bore clearance.
I can see where the problem is. As long as you run the smaller valves you will be fine with them in a 305..
Old Dec 13, 2004 | 08:10 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I can get her to about 5600rpm in my Roc. The stock heads being ported are pointless without the intake and runners being changed(not truly pointless but better with a full upgrade).
I love my LB9, sure it is not as fast as a L98 when stock or modded but who cares have fun with what you brung!!!
Old Dec 13, 2004 | 11:32 PM
DON 88T/A's Avatar
Where you spin the motor is based ion the intake...long runner TPI you might get a little over 5000 grand...a LB9 should handle that...just remember these motors are getting old..the bearings/rings ect.have been through alot...the 305's are workhorses..I know..I have one and it has run good for me for a long time...but you start adding alot of power on a 15+ year old bottomend...well you just don't know.
Which is why people just suggest a 350 since a rebuild is going to be needed sooner or later its not much more for a 350.
I think a heads/cam 305 TPi could run very decent set up right...
port the stock heads or get a set of aluminum L98's...something around the ZZ9 spec cam...would be a very solid performer with all the other usual mods...
Old Dec 13, 2004 | 11:34 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
I have a roller 305 that I spin to 6500 rpms
stock bottom ent 750 cfm carb
later
and
GB
riuck
gta90
Sep 15, 2015 04:00 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
kyleb24
Aug 15, 2015 08:24 AM
