how to tell if running on 7 cyl
Old Dec 11, 2004 | 10:34 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok guys, appearently my mechanic said that #7 injector is dead using a injector balance tester bu they are brand new accel's is that possible
how would i tell, it seems to rev up fine power seems like its there.
Old Dec 11, 2004 | 10:51 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: how to tell if running on 7 cyl
You would notice if you were running on 7 cylinders...maybe you need a different mechanic. Do a search here on the boards and you will find tho that a lot of people dont like or have had problems with Accel. Myself included....
Old Dec 11, 2004 | 10:53 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
unplug the #7 injector and see if it runs the same. if it runs crappyier its probably not the source.
you need to give more information on your problem.
Old Dec 12, 2004 | 04:31 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
can injectors brand new come like that can the pintle all the sudden just free up like get lubrication or something... when i unplug any injector at idle nothing changes, the supposed dead injector pulled 15.2 ohms resistance he used a injector balance tester and showed me it tests each injector indvidually it didnt fire but can they all the sudden start working
Old Dec 12, 2004 | 04:57 AM
contactpatch's Avatar
Engine: sbc 350
Perhaps you could swap in, a known good injector,
just for testing.
Old Dec 12, 2004 | 11:16 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you have headers just spray water on the header with the suspected dead cylinder. It should not burn off very rapidly as the ones with the live cylinder will. This will not work with cast iron exhaust manifolds. Allen
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
fasteddi
Sep 2, 2015 10:29 AM
perZ
Aug 21, 2015 05:51 PM
