Car won't start after warmed
Old Dec 20, 2004 | 03:42 PM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
My car used to not won't start unless I put some starting fluid in it. I checked the fuel pump and it is good, so I replaced the fuel pump relay. After the replacement, the car cranks up fine when it is cooled be If I let it warm up for about 15 min, then turn it off and try to crank it back up, it will not crank. Oh yeah, I also received a code 24, but I don't think this code has nothing to do with it.
Old Dec 21, 2004 | 11:01 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Your starter solenoid is probably heat soaking. My car used to do the same thing. Do you have headers? They will only make the problem worse.
I used a remote mounted solenoid and put my battery in the trunk. Problem solved.
Old Dec 21, 2004 | 03:46 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Describe the no-crank.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
