autometer electric Oil pres. guage
Old Dec 22, 2004 | 03:47 PM
KiLLJ0Y
Guest
Posts: n/a
how do i go about hooking this sending unit that came with the guage, up to the engine?
my Car is a 92 with a 350 TPI, is it the same place where the oil filter is? or on the back of the engine block near in the intake? the instructions are not "car specific" so im not sure where this sending unit goes.
can anyone help out?
Old Dec 22, 2004 | 06:29 PM
KiLLJ0Y
Guest
Posts: n/a
anyone know? someone does.. help me out
Old Dec 23, 2004 | 09:27 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
What you'll need to do is attach it to the rear china wall on the block. I've got an oil pressure gauge and that's what I have to do. Unfortunatly I've been to lazy to rip apart my TPI so I can see what I'm doing. You also may have to modify your intake so it can screw into it. Just remove the plug and go to town. This is how they used to do it on older cars.
Old Dec 25, 2004 | 10:27 AM
smokingss's Avatar
ok, i installed a mechanical oil pressure gauge on my 87 tpi 350 motor. its a 92 TPI system on it though, but 87 block should be same as 92. the electric sender goes the same place. Behind the intake manifold on top of the block there should be a sending unit installed already or at least a plugged hole. you screw the new sender right into that. make sure to use teflon tape to prevent leaking. IIRC the sender port by the oil filter is also for the fuel pressure switch and other stuff for the computer so try to stay away from that one if you can. If you need a pic of exactly where the top hole is located, i have another 350 tpi block on a stand with no intake or heads that i can take a picture of.
Old Dec 25, 2004 | 07:36 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
here is a shot of my old LT4, you can see the oil pressure fitting screwed into the back of the china wall on the top left of the block, that is a 2 piece fitting.
Old Dec 26, 2004 | 07:21 PM
KiLLJ0Y
Guest
Posts: n/a
awesome, thanks guys,
i appreciate it
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
