VATS car with non VATS computer...
Car: '91 RS, F41
Transmission: WC T5
i have searched and came up empty. will i have problems putting a non vats computer for my TPI into my 91 car with VATS?
Car: '91 RS, F41
Transmission: WC T5
i currently have a 91 with TBI and i am swapping to TPI. The TPI is a mass air system from an 87 iroc. I was wondering if i would have trouble with putting a computer without VATS into my car that has the VATS system. Will my car still start or will i have to bypass it by putting a resistor in? Sorry if that is confusing lol
Car: '91 RS, F41
Transmission: WC T5
What do you mean by repinning? I have been researching this quite a bit, but im still at a loss on a couple of things. I have the harness from the computer to the engine bay, isnt that all i need? Can i just unplug my computer and plug the 87 in using the same harness from the computer to the dash? i hope thats not to confusing. Can you explain what repinning is? i have searched around and cant figure out what it is. thanks
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
There is no one connector that goes to the engine and one that goes to the dash... both connectors go to the engine bay. Very little of the wiring harness runs to the dash. There should be TBI-TPI swap threads that explain all the to-do in abundance... there's also entire books written on the subject... the info you need is definitely out there.
