TPI Computer
Old Dec 27, 2004 | 01:11 PM
ThirdGen's Avatar
TPI Computer
Hi, im planing on running an air gap type intake, i would like to drill it out for 8 injectors like the tpi's and lt1s have... but i dont want to run all that wiring... what do i have to run? besides the computer to get them to fire right? what's easier to burn chips for tpi's or lt1s and witch cost less? any help would be great!
Old Dec 27, 2004 | 06:13 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I would stick with the GM ECM. You could do a Mega Squirt if you like and are good at wiring and lots of other stuff. For the TPI harness you can rip out all of the emmissions control device wires and add some new colorfull loom. You have to have MAT, CLT, TPS, Knock, Distributor stuff, Injector wiring at the least. If you want a very informative thread making the intake, check out the search button on "single plane EFI" in the DIY prom boards, it is under anthesis' name. I am also in the middle of doing one right now. Make sure to use the Search button.
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
