Ditching 89 exhaust
Old Dec 27, 2004 | 06:09 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Ditching 89 exhaust
I'm planning to replace my rusty exhaust manifolds with headers and it would seem 2 and half or 3 inch is the defacto 3rd gen choice for performance pipes but I also don't think I'll be upping engine internals for a bit (SLP is a strong contender for the parts)... What are some other good, proven choices for the L98 staying mostly stock. Can I get pipes that would work under both conditions? Stock and then slightly modded for higher HP? I'm thinking the most useful HP range for me is low end torque as my car seems quite capable of speeds 60 or faster, unfortunetly, no autobahn near here
Bill
Old Dec 27, 2004 | 06:45 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
I have a mufflex 4 inch exhaust just so you know that it exhists. I also have the slp's 1 3/4 inch headers Its a cool little job because you will probably have manifold bolts break and some and a few of the headers will interfere with the brackets where you will have to do a lil grinding or cutting so they are not to interfere with the tubes.
The exhaust system alone isnt going to help you break any records. Find an exhaust note you like on any 3rd or 4th gen and get it for your self.
Old Dec 27, 2004 | 07:21 PM
Bill Speed's Avatar
Engine: L98 350 TPI
Exhaust tone is not a priority but I want to open up any restrictive breathing imposed at the TPI inlet or the pipe section, just a hair above the factory so I keep the fuel efficiency.
I'm particularly interested in stainless steel to keep from replacing them time and time again. My waterpump is rusty too but doesn't seem to be a leak culprit
Bill
Old Dec 28, 2004 | 01:42 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Hedman ceramic coated shorties, they keep underhood temperature down and are great for a stock or modded engine. I looked at 1 3/4 or full length but the gains are minimal. 3 inch exhaust is what you want.
Old Dec 29, 2004 | 10:15 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have the hooker log tubes and then I went to an exhaust shop and paid $50 to have a TRUE dual exhaust set-up made that I can take down in three min. For $50 it can not be beaten, or out flowed.
Old Dec 29, 2004 | 02:31 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
is the $50 custom job something you go to a Hectors muffler shop and beer store, or can a Midas do it "on the down low"?
Old Dec 29, 2004 | 03:08 PM
Bill Speed's Avatar
Engine: L98 350 TPI
I have the factory dual cat setup that isn't two pipes front to back but would still like to maintain the factory pipe placement on a budget. Post any pics and prices too. This is something I will address a little later, as my pipes are still functioning for now.
Bill
Old Dec 29, 2004 | 07:46 PM
robsgta's Avatar
Uhhh ummm some pics of a true dual 50 dollar exhaust job that cant be beaten needs to be verified with a few pics...
Old Dec 30, 2004 | 01:30 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I do not have any pics of the set up to scan right now. The price only includes pipe, hangers, and labor. It was an actuall "race" shop I went to also, so I do not know what kind of a job midas would do. What do I have to gain from making that up?
Old Dec 30, 2004 | 04:08 AM
Bill Speed's Avatar
Engine: L98 350 TPI
Midas might set you up with Walker pipes, and they rusted right up on me.
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
customblackbird
Oct 1, 2015 04:30 PM
gta_knight
Sep 23, 2015 04:59 PM
david068513
Sep 18, 2015 10:36 AM
