RC Engineering fuel injectors
Old Dec 28, 2004 | 11:46 AM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
Has anyone tried these, or have any experience with them? I'm trying to look at all of my options, but that is hard to do when I don't have any info on these. I can't do a search because "RC" is below the three charicter rule for our search feature. Thanks in advance for any input.
Brandon
Old Dec 28, 2004 | 05:45 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
RC Engineering tends to cater to the import world...I don't think I have ever seen a thread about them on TGO. I do remember them from my days of owning a Turbo Talon and I believe that they were ok. They are just a vendor and re-sell mainbrand injectors.
Were you looking to pick up a set for your Thirdgen?
Old Dec 28, 2004 | 08:56 PM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
Thanks 88TPI406GTA. Yes, I am currently looking for a set of 36# injectors for my 91 Z28. I'm just trying to study what's out there before I make a purchase. I'm also on the fence as to weather or not I need 36# injectors or not. I think injectors as small as 30lb/hr will work, but I would like to have the ability to expand if I decide to. Do you have any suggestions on an injector type? I'm am looking to be making between 450-475 hp. Do you think I should be going with 30# or 36# injectors? Accel makes a 32# injector that I have been looking pretty closely at. Any input is greatly appreciated. Thanks.
Old Dec 28, 2004 | 09:14 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Stay away from the Accel injectors....too many people seem to be having problems with them.
Old Dec 28, 2004 | 10:36 PM
Engine: LS3
Transmission: 6L80E
The 30# injectors would work...but they are pretty well maxed out at 475-490 HP...you can make it work with higher FP, but I would consider the 36# SVO injectors...no problems there.
Good luck
Old Jan 3, 2005 | 09:17 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I am in the same boat. I am putting in a 383 HSR that will be around 450-475 hp. I have read on TGO that the SVO injectors are rated at 39 PSI and GM injectors are rated at 43.5 PSI. I called fiveomotorsports and they say the 30# injectors will work by increasing the fuel pressure to around 48 PSI. I'm still not sure that I want to push my fuel pump too much. I agree with TheGreatJ, stay away from the accel. SVO's appear to be the injector of choice.
Old Feb 21, 2008 | 07:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: RC Engineering fuel injectors
From the dead!
I just bought some RC injectors for my Iroc, If I have any problems with them I post here about it, otherwise, assume they worked just fine.
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
