Those of you with an Lt4 Hotcam... vacuum question...
Old Dec 30, 2004 | 08:41 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Those of you that are running the LT4 HotCam, how many inches of vacuum are you pulling? I just got my car running today, on an almost stock AUJP and the brakes are horrible if I step on them with the clutch in (engine idling). If I leave it in gear and then step on the brakes, they seem fine. By leaving it in gear, the engine is staying at a higher rpm, and producing a higher vacuum reading. I think I am at 11-12 in at about 850 rpm. Brakes fine when I am at 15 in or so.
I'm going to play with the spark tables and lean the bottom end out a bit tomorrow. Hopefully it'll get better with the timing change.
By the way, this was with the vacuum reservoir disconnected. I haven't tried with it hooked up.
Old Dec 31, 2004 | 07:30 AM
kevinc's Avatar
Car: 1982 Z28
Mine pulled 13-14" of vac at 750rpm idle. With stock brake booster, no vac reservoir, the brakes were fine. No hard pedal any time I used them.
I never ran stock software, tho, and I didn't use AUJP as my base image w/ the 6-speed. I found a Vette image that had manual trans, and used that as the base. Just didn't want any issues w/ the idle behavior, and figured AUJP wouldn't manage it right if it thought the car was in Park/Neut all the time.
Old Dec 31, 2004 | 12:25 PM
anondude13's Avatar
I think 14 is the norm. I haven't tested mine, but the brakes are good.
Old Jan 1, 2005 | 05:40 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Well, I tried it with the vacuum reservoir hooked up and didn't notice a difference. I played with the spark tables and leaning the bottom end out and got it to idle quite a bit nicer and its at 13-14 now. Brakes are working a hell of alot better now. I guess that 11/12 is really close on the booster's requirements. I think it might even gain another inch or two if I keep working on idle. Its still not right.
Old Jan 2, 2005 | 07:26 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
I was recently running the hot cam i was pulling 18" @ 850 rpm,but i also had total seal rings....funny story machine shop checked my valve guides said they were very good...well the thing smoked like a frieght train when i hit rougly 5000 rpm,tore the engine down needless to say backs of the valve were seriouly carboned from the oil being sucked past the valve guides
Old Jan 3, 2005 | 12:46 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What is your MAP reading saying at idle?
Old Jan 3, 2005 | 05:45 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
i had changed it over to a carb setup....in the process of doing the HSR swap with pro topline 200cc's....hopeing for mid 12's
Old Jan 3, 2005 | 06:07 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
About 45 kpa
Old Jan 4, 2005 | 04:43 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I usually see high 30's. What is stock idle MAP?
Old Jan 6, 2005 | 01:23 AM
Stephen Thomas's Avatar
Car: 84 Trans Am
Engine: 5.7 zz430
Mine is carbed, but 16" with my 600 cfm edelbrock, 15 with my 750 cfm demon
Old Apr 8, 2006 | 09:34 PM
89_fireform's Avatar
Car: 89 WS6 formula firebird
Engine: 305 TPI :(
hmm good info im looking to get the same cam
Old Aug 2, 2011 | 09:55 PM
Car: 84 Trans Am
Engine: 5.7 zz430
Re: Those of you with an Lt4 Hotcam... vacuum question...
Yeah mine runs about the same 17" with my 600cfm edlebrock. Around 14 with Demon 750
Old Aug 3, 2011 | 02:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Posted 04-09-2006
One would hope he has sorted his problem out by now
Old Aug 3, 2011 | 09:40 AM
Car: 84 Trans Am
Engine: 5.7 zz430
Lol. Yeah I was searching for something and completely missed tge date.... Lol
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
dusterbd
Sep 29, 2015 08:40 AM
