CAI Elbow for TPI
Old Dec 31, 2004 | 08:04 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
CAI Elbow for TPI
Anyone ever use the LTI Air Inlet elbow(metal) that Summit sells on a TPI setup?? Its the the 90*elbow that fits beteen the TB and Mass sensor. I havent seen that elbow for a TPI Fbody and it looks like it would work if you just face it 180* out because the filter is on the opposite side of engine bay.
Old Dec 31, 2004 | 11:23 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yes, I use one on my custom cold air intake. I had to get a longer hose from the throttle body to the LT1 elbow. The hose is 4 inches in diameter. The end towards the filter is 3.5 inches. I made up a special adaptor out of a plastic fitting to reduce the 3.5 inches to 3" of the MAF. You can buy silicone hose that will do the same thing.
I also made a bracket to relocate my MAF about 4 inches to the passenger side. From the MAF to the air filter I used 3.5 inch tubing. Again I had to make an adaptor to go from the 3 inch MAF to the 3.5 inch tubing.
I used a K&N cone style airfilter with a 3.5 inch inlet and total length of 9". The "weak" spot is the MAF at 750CFM modified with the screens out and the fins cut. Allen
Old Jan 1, 2005 | 11:41 AM
Car: 89 Formula 350
ok, cool I'm glad to hear it will work. I might not run into a problem having to get longer hose beteen the TB and elbow because im running a Super Ram and it seems to extened further foward then the stock TPI. 1989GTATRANSAM what brand elbow did you use??? I see Summit selling 2 brands - Trick Flow and Vortech
Old Jan 1, 2005 | 02:29 PM
Car: 1989 GTA
Engine: 369 TPI
I bought the Trick Flow and the ceramic coated version. There is a hole for I believe the air temperature sensor for the LT1. I just plugged it up. Allen
Terrell351
Jun 13, 2021 01:13 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
