TPI LT1 blocks
Old Jan 6, 2005 | 07:35 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
TPI LT1 blocks
Are there any differences in an L98 and LT1 block? im thinking about changing to an LT1 but without the opti spark and i dont want to run the reverse water pump. Can it be done?
Old Jan 6, 2005 | 08:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
http://www.lt1intake.com
Old Jan 6, 2005 | 10:22 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
I think he means Tune Port on a LT1 block. Not LT1 intake on a SBC. I think?
Old Jan 6, 2005 | 11:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Hmmm . . . maybe... Where the water pump bolts on is alot different on an LT1 (can't just bolt on a standard SBC pump)...
Old Jan 10, 2005 | 04:28 PM
Firebird90V6's Avatar
An LT1 block is ALOT different then a small block chevy.. The LT1 is reverse flow colling, and like you said uses OPTIJUNK. Your best deal is use a modified LT1 intake on a SBC like previoulsy stated. Trust me, the LT1 is great in my 95 TA but in no means would i ever transplant one into my 85. NEVER. I will be using the intake though.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
