Miniram Fuel Rails
Old Jan 10, 2005 | 12:06 AM
89406Iroc's Avatar
Miniram Fuel Rails
Does anyone have any pictures of miniram fuel rails that have been bored or such to run a parallel fuel lines through the rails?
I did a search and couldn't pull up any of the pics that I had links too or had saved. I am curious what was done in the front of the rails for clearence for fuel lines.
Thanks, Chad
Old Jan 13, 2005 | 10:10 PM
89406Iroc's Avatar
Does anyone have pics of the tt vette with miniram >1000hp I believe. Or any pics for that matter.
Old Jan 13, 2005 | 10:39 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
What are you asking for again?
The fuel lines that come from tpis are crappy. You can use braided line to clean it up and get some more room for clearance. Do a search, it has been covered before if that's what you are looking for.
Old Jan 13, 2005 | 10:45 PM
89406Iroc's Avatar
Looking to see what people have done for the rails themselves. I am running a sumped tank and different fuel system so I want to eliminate the split wall fuel rails and modify them so there is one passage through the rail but need a fitting at each enc of the rail. Want to chewck out and see what has been done. I've done the searches and only pictures are no longer active.
Old Jan 14, 2005 | 10:26 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
You will just have to have a shop weld some bungs onto your rails.
http://www.rossmachineracing.com/extrusion.html
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
