Help on 86 corvette PROM DIY Question
Old Jan 11, 2005 | 12:21 AM
AvantiHall's Avatar
Car: 64 Studebaker Avanti,67 ElCaminoTBI
Engine: GM 350 10.5:1 Supercharged
Axle/Gears: 3.54 posi
I'm a newbe with lost of reading.
Have read every thing I can find and still can't find what area to change air fuel ratio while in close loop.
Have found and "Corrected" cold starting, accel problems, popping back in intake, rough idle, pinging, time to go into close loop.
Can't find the area to correct Idle 140 blm and 120 blm rest of the area.
C.A.T.S. Tuner RT $32
with TunerPro to do PROM
ECM 165 stock prom AANM
Old Jan 11, 2005 | 06:06 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Help on 86 corvette PROM DIY Question
Load vs RPM table.
Though I dont remember if idle has its own fuel routine.
I really hate that old MAF stuff.
-- Joe
Old Jan 11, 2005 | 02:29 PM
AvantiHall's Avatar
Re: Re: Help on 86 corvette PROM DIY Question
Originally posted by anesthes
Load vs RPM table.
-- Joe
Thanks for the Help Joe
Is that BPW Fuel Table vs Load vs RPM ????
Dave
Old Jan 11, 2005 | 07:38 PM
Vader's Avatar
Since you're using Mr. Mansur's TunerPro,what *.ecu file are you using?
Old Jan 11, 2005 | 08:57 PM
AvantiHall's Avatar
6Ev011.ecu
But the data is off some with 6Ev011.ecu. So I have been using RT_Tuner and am trying to find the way to adjust the mixture in close-loop.
Old Jan 14, 2005 | 11:54 PM
Vader's Avatar
There is a target A/F ratio parameter in 6E, V011, but that is closed loop. I believe it's at 3D5/3D6.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
