Stealth Ram coil Mounting
Old Jan 11, 2005 | 11:32 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Stealth ram users, how did you mount your coil? Please post pics if possible.
Old Jan 11, 2005 | 12:15 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Stealth Ram coil Mounting
run a search and you should find something on this. Its been asked before. I mounted mine upside down under the wiper lip on the passenger side temporarily. Dont have a pic at the moment.
Old Jan 11, 2005 | 12:31 PM
kevinc's Avatar
Car: 1982 Z28
Same location as it was on the TPI setup, but I had to make a U-shaped cutout at the base of the coil bracket to clear the HSR's intake runner.
Two hacksaw cuts, then bending the section to be removed made a nice clean break. I used a file to smooth the cut area before installing it.
Old Jan 15, 2005 | 12:13 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Re: Stealth Ram coil Mounting
I did the same thing. Seems to work ok. car made it around the block twice.
Old Jan 15, 2005 | 10:51 PM
BOTTLEDZ28's Avatar
Transmission: A4
I reused the stock mount but grinded the holes so that I could slid the bracket under the last 2 intake bolts to install it. IIRC, I had no choice on 1 of the holes and I think I also had to grind off some material in the middle of the bracket to clear something on the intake. its been a year so I really dont remember that well.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stangski09
Nov 14, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
