FMS injectors
Old Jan 15, 2005 | 07:25 PM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
FMS injectors
i just intalled the ford motor sports injectors in my fuel rail but the metal clips that lock them in dont fit on the new injectors ......... do i really need them? wont the bolts that hold down the fuel rail hold the injectors in?
Old Jan 15, 2005 | 07:40 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
The clips should fit...may take a little work, but they should fit. I had a hard time getting the clips on mine, but the went on. Just be careful because they bend out of shape really easy.
Old Jan 16, 2005 | 04:18 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
on my injectors the groove where u put the ring on is only like on the sides of the injector its not a full circle around like the stockers so i cant fit the rings on
Old Jan 16, 2005 | 04:28 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: FMS injectors
I don't used them on my 388.
Old Jan 16, 2005 | 07:39 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
I'd cut them in half and use the side with the tab on it. Better than none, IMO.
Old Jan 16, 2005 | 03:36 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
rgarcia63: u dont use the clips and it works fine?
Old Jan 16, 2005 | 07:05 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes, the reason I see for the retainer clips is on the factory assembly line, because once installed it's the fuel rail that retains them, if they leak at the fuel rail, or the intake boss, it's not because of the retainer clips. Either the bosses are to big, wrong/damaged O-rings, Fuel rail bolts not seated right, or they're the wrong injectors.
Old Jan 16, 2005 | 10:39 PM
Guest
Guest
Posts: n/a
Not everything is totally the same from one part and one car to the next. I have seen some that you can move the injector all the way against the rail or manifold and break the o-ring loose from the seat. That could prove bad on a running car. Some people have cut the groove the rest of the way around. Are you sure it doesnt have the groove? Mine did.
Old Jan 17, 2005 | 12:42 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I can't speak for others, but I took the factory set of injectors out for maintenance, and they needed to be fully seated in the fuel rail to install the retaining clips, when I upgraded to 30lb injectors I compared the retainer slots to top of injector distance to the OEMs and they were the same. I fully seated them without the retainers before installing into the intake, and checked the vertical play with the fuel pump on and pressure at 60psi for leakage, there was none.
Old Jan 17, 2005 | 09:53 AM
Guest
Guest
Posts: n/a
As I said, not all the manifolds and injectors are the same from stock to aftermarket. I've not only unseated injectors without clips, there have been people that have had it happen to them.
There is a reason the factory used them, besides production. Anyone thats thrown an injector in a rail knows they arent gonna just fall out from gravity anyway.
Old Jan 17, 2005 | 09:59 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Granted you do not need the clips. However, I have two practical reasons to use them,
1) if the clips go in, I know I have the injectors installed & seated in the fuel rail,,,
2) With the clips in, when I pull the fuel rail off, the injectors come off with the fuel rails.
My 2 cents worth.
Old Jan 17, 2005 | 10:22 AM
12secformula's Avatar
Car: 94 Z-28
IMO the clips are necessary. The bore on the fuel rail and the manifold are longer than the injector is. You can easily slide the injector up and down in the bores if installed w/out the clips, although this may not break the seal that the o-ring has made. Over time the seal may be broken and affect performance. My FMS 30lbs injectors had the full groove around the injector for the clip. Above that there was grooves only on the sides.
Old Jan 17, 2005 | 06:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I agree with 12sec, the clips do force the injector to the best seated position to get the best seal at the top and bottom of the injector.
Old Jan 17, 2005 | 11:07 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I didn't put mine in, although I could have, that was my decision based on measurements taken which didn't deviate enough to cause concern, but I don't have the stock intake, and I couldn't force the injectors into the intake bores all the way without using the fuel rail bolts, and I did lube the O-rings.
Old Jan 17, 2005 | 11:30 PM
anondude13's Avatar
I didn't use them either. A lot of people don't. They're good if they'll fit, but not necessary.
Old Jan 17, 2005 | 11:32 PM
Car: 94 Z-28
I really have to use my clips. I lost one and considered putting it in w/out it, but I can move the injector so far up and down that it can almost come out of the bore. Plus I didn't want to risk it.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
