Canister red plug = trouble
Old Jan 18, 2005 | 05:20 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Hey guys
When i bought my car i noticed that the sensor that plugs into the canister on the front of the car on the passanger side was disconnected. I plugged it and went for a drive. As i was driving the car started missing really bad. THE Tac needle would go up and suddenly drop to 0 and go back up and drop again. I pulled over and unplugged the sensor and the car ran fine again.
What does this mean? That sensor is supposed to be plugged in
I have a 85 TA with a 305 TPI
thanks
Old Jan 18, 2005 | 06:29 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Either you have a bad canister purge solenoid or a charcoal canister thats full of fuel. Probably the latter.
It's strictly an emissions device....if you don't have to have it for inspection, leave it unplugged.
Old Jan 19, 2005 | 08:33 AM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
is that why i can smell gas when the car is running? i just had tune up done. Do I need to keep the canister if im switching to carb?
Old Jan 19, 2005 | 02:53 PM
BOTTLEDZ28's Avatar
Transmission: A4
you can toss that can in the garbage if your switching to a carb setup. I bet half of the EFI guys here dont even use it. Im running EFI and my canister is sitting in a landfill right now along with everything else connected to it.
Old Jan 19, 2005 | 04:43 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
i live in chicago and they do emissions
Old Jan 19, 2005 | 06:46 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
If you live in an area where they will be checking emissions they certainly won't like the fact that you're pulling off the factory EFI setup and reverting to a carb.
IMO, you should fix the problem. It doesnt' cost any power, so why remove it?
Old Jan 19, 2005 | 06:47 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
ive been wondering if switching from FI to carb will get me in trouble with emissions
Old Jan 19, 2005 | 10:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
Get a bottle of "emissions in a bottle" from Auto Zone. It works for me everytime.
1992 Trans Am
May 10, 2023 07:19 PM
Glowsock
Jan 9, 2017 04:06 PM
kairles
Oct 26, 2015 09:13 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
