code readers
Old Feb 7, 2005 | 04:32 PM
Johnnywilde55's Avatar
Car: 87 Iroc, 88 Camaro
Engine: 5.7L TPI, V6
Transmission: 700r-4, t56
code readers
what is a good code reader that isnt that expensive, so i can check out if my car is shoting any trouble codes
Old Feb 7, 2005 | 05:20 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
a paperclip.....cost less than a penny
Old Feb 7, 2005 | 05:23 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
yep, just connect the A and B i believe in your plug under ur dash on the drivers side when the cars off. just dont start the car up with the clip in there
Old Feb 7, 2005 | 05:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Amateurs... as the guy with the apparel that just can't resist a magnet says...
Originally posted by Vader
If I'm correct in my guess, the "fix" will depend upon the variety of possible causes. However, since I'm guessing, you should diagnose the problem first. Retrieve the error code before it gets erased.
First, you'll need to acquire a GM OBD I ECM Diagnostic Trouble Code Retrieval Tool (commonly known as a paper clip to TGO members). Form this wire into a ‘U' shape.
With the engine and ignition turned off, locate the ALDL connector under the dash, just to the right of the steering wheel in the driver's foot well area on some models, and on the left on others, depending on the make and year. There should be a small rectangular cover over the access hole in the lower dash trim, or at least was when the car was delivered.
Insert a tool as described above (paper clip) into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) - it will begin to flash. This is also commonly called the "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Once you have a note of all error codes, check this file for the decoding:
GM Error Codes.pdf.
You'll need Adobe Acrobat Reader to open/print the file.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
