I'm way faster then all of you!!!!!!!!!!!!!!!!!!!
Old Feb 10, 2005 | 10:33 PM
NEEDforSPEED's Avatar
No, not really, but hey i got you in here, and now that i did you might as well read on...
I have an engine in the works, and I need some input as this build gets going...
I'll give you a list of some of the parts im running
i want to pick a good cam, so im going to need some help there, i was going to run "083 castings" but i plan on selling them and putting the money tords the modded LT1 heads, i was looking at a lot of different roller cams but im not that good when it comes to the best cam for my combo...
Fresh 2000 5.7 vortec, 2-bolt main - stock everything,
LT1 intake, port match to the heads,
No EGR, either 24lb or 28lb injectors,
LT1 heads , Gasket matched, bowl work, mildly ported and exhaust fully polished, what comp ratio should i go with
When i look into head gaskets?
shorty headers, 3" piping, y-pipe - back, no A.I.R or emissions, probably run no cat either,
a really good better then stock ram air with a good breathing airfilter,
Rebuilt 700r4 with shift kit, witch stall?
Aluminum drive shaft, 3.27, limited slip pois...
i have no clue what to see for rear wheel HP and TQ with this setup....
anyhelp will be great....
Old Feb 11, 2005 | 07:37 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
or you can always put one of the delta 4 rockets boeing came up with... 17 million hp... that would be cool man. talk about being fast, i think your skin would peel off your face if you went that fast
Old Feb 11, 2005 | 10:26 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: I'm way faster then all of you!!!!!!!!!!!!!!!!!!!
Compression ratio depends on what cam you want to run. If you get a large duration cam, don't go below 10.0:1. I f you go with a smaller cam, you would be OK in the 9.0:1 ranges. You would only need the 24lb hr injectors, unless you are going for a high winding motor.
no green
Mar 3, 2016 05:19 PM
toones
Jan 6, 2016 06:00 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Americanmouse
Sep 7, 2015 12:10 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
