LT4 hot cam clearance
Old Feb 10, 2005 | 08:32 AM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
Has anyone ever had clearance issues with 1.6 rr on a stock 350 tpi engine? Valve cover, piston..etc
Thanks.
Old Feb 10, 2005 | 10:21 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You will be fine. The valve covers and springs are more of the problem area.
Old Feb 10, 2005 | 11:44 AM
anondude13's Avatar
I think valvecovers are fine since hotcam was usually sold with 1.6 rr's as an upgrade to the LT4. You will need new springs tho. If you want to get LT4 hotcam, just get the kit, it has the cam 1.6 RR's, and springs. There are better cams out there for power, but hotcam will pass emissions and get decent mileage.
Old Feb 10, 2005 | 12:15 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Question:
i have the LT4 HOT Cam.. and i see SLP now sells the LS6 Valve springs, and says they will work with out cars. i would expect these springs can handle the LT4 HOT Cam, correct?
anyone have the retainer part #'s
im going to be using 1.5 roller rockers.
Old Feb 11, 2005 | 11:45 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
r3pp3r, I live in Cali, do you know for sure that the hotcam will pass emissions? Will it pass as is or will it require some "de-tuning?"
thanks
Will
Old Feb 11, 2005 | 02:13 PM
hot68's Avatar
Car: 68
Engine: 383
Transmission: homebuilt 4l60
My 1.6 crane rollers with this cam would not clear stock valve covers. I didn't try the real thick vc gaskets but that might have been an option...
Old Feb 11, 2005 | 03:12 PM
anondude13's Avatar
_
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 22, 2015 06:52 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
