Remote mout coil to HEI swap
Old Feb 11, 2005 | 10:36 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have decided to go back to the 7730 ecm from megasquirt until Ultra Mega Squirt comes out. So I have to change distributors, from vacuum advance to electronically controlled. I have my old wiring harness that I will use, but that was for a remote mount distributor. I am wanting to do a HEI coil in cap swap though and was wanting to know how to wire it. Thanks.
Old Feb 11, 2005 | 11:58 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
They are both 'HEI'. Why do you want to swap to a coil in cap? I doubt you'd see the RPM to get any scatter if that is what you are worried about.
Old Feb 11, 2005 | 03:09 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Sorry, I just caught the mistake I made. I am not making the swap for any kind of power or anything. Just that I got an Accel cap in coil distributor, cap, rotor, and coil for free. So I want to use them and I like not having to mount a coil. I have heard that Accell makes a conversion to go from in cap to external, can I use it to go reverse or what other way to do it?
Old Feb 12, 2005 | 03:47 PM
Damon's Avatar
The Power and Tach connections are fairly straight forward.... on the 2 wire connector of the main wiring harness that used to go to the remote coil you connect the big pink wire to the "12V+" or "BATT" connector on the coil-in-cap distributor. The smaller white wire from that same connector goes to the "TACH" terminal of the coil-in-cap distributor.
BUT..... the ECM connections are totally different between a coil-in-cap computer controlled HEI and a divorced coil computer controlled HEI. I can't help you with that part of the wiring. I don't even know if it would be compatible by jsut cojnecting the appropriate wires together.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
