Stuck egr bolt
Old Feb 12, 2005 | 10:07 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
Stuck egr bolt
hey guys i have a bolt that holds the egr valve down that is rounded off. its the one near the driver side. what can i do to get it out?
Old Feb 13, 2005 | 09:12 AM
Vader's Avatar
Chan-nel-lock pliers, number 410. Don't use any other pliers or Vice-Grips, just the 410's.
(Bet he thinks I'm kidding - Who wants to bet?)
Old Feb 13, 2005 | 09:24 AM
brutalform's Avatar
If I remember correctly, when this happened to me, I know I applied heat, and I think it was a 10mm socket I modified to get it out.
Old Feb 13, 2005 | 09:25 AM
brutalform's Avatar
Sorry, I didnt catch the rounded off part....
Old Feb 13, 2005 | 10:07 AM
Kevs87Z28's Avatar
Engine: 355 Carb
410 channel locks.... no other way? if thats what will do it then so be it i will do that. i guess i shouldnt cut the head off and drill it out?
Old Feb 13, 2005 | 10:37 AM
91Z28-350's Avatar
http://www.sears.com/sr/javasr/produ...ab=des#tablink
http://www.sears.com/sr/javasr/produ...id=00952160000
Old Feb 13, 2005 | 02:20 PM
Vader's Avatar
No, it's not the only way. It's just an easy way. You could cut/drill/tap if you choose to do so. The nice thing about the 410s is that they won't slip. The bolt will either twist off or come loose. If it is fused so badly that it twists off, any other extractor wouldn't do any better. If you can fit the plier jaws in there, it will turn it. Period. Vice-Grips (even the genuine Petersen ones) don't hold a candle to the gripping power. Knipex (Germany) makes some nice self-gripping pliers as well, but they still aren't as good as the 410s.
Old Feb 13, 2005 | 03:48 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Don't forget to use anti-sieze on the threads when you re assemble!
Old Feb 15, 2005 | 08:37 PM
Kevs87Z28's Avatar
Engine: 355 Carb
hey guys! intake manifold gasket was blown so i pulled everything and after i got the fuel rails off i got to that bolt easy and it came right off. see before i could only get a wrench on 1 way and that way was already stripped but after i pulled the rails it made it 1000 times easier and it came loose with little effort. thanks for the help!
Old Feb 15, 2005 | 11:38 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Vader, are the 307 and 414 also worth getting for the smaller and larger bolts?
JHX
Aug 29, 2015 02:30 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
